Question about Epic 425 Mx Treadmill EPTL88105 !
Replacing front roller remove - Epic 425 Mx Treadmill EPTL88105 !
How do I get to drum rollers kenmore he2
Lift top and tilt back, remove 2 top screws and 2 bottom screws, remove wires from door switch, lift front up a inch and pull out of drum and set front off to the sides. Rollers are attached to rear panel, remove roller retainers, and replace rollers, then reassemble.
Jul 26, 2015 | Kenmore Dryers
I need to replace the motor belt but i can't remove the front roller of my H140t Healthrider treadmill
There is one screw in the front roller
  1. Loosen the rear roller
  2. Remove drive belt
  3. Remove the 1 screw in front roller
  4. Pull roller out
Jan 01, 2014 | FreeMotion HealthRider "Club" Series H140t...
Belt stops running although you can hear motor running. How do you replace front roller pulley?
Loosen off the rear roller adjustment bolts, 10 turns each side counterclockwise.
Remove the motor drive belt.
The front roller should now be removable. If you have difficulties, back off the rear roller adjustment bolts 3-4 turns further. Keep track of how many counterclockwise turns so you are able to readjust the belt after replacing the front roller pulley assembly.
Repeat the instructions in reverse once the front roller is in position.
Dec 16, 2010 | Epic View 550 Treadmill
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
The treadmill is loose. How can this be fixed?
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud, then find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability.
If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt Tighten the bolt and test. If the problem is not corrected, repeat steps above and retest.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. Follow this procedure:
First remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Rear Roller Adjustment Bolts
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley and front roller must be replaced.
Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud. Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. then remove front roller and replace with new reverse procedure mentioned above
May 16, 2010 | Proform Sport 1000 Folding Treadmill...
Tub won't turn belt broken ,how do you replace belt?
You can remove the lower panel below the door and see the motor and belt. To replace the belt you need to unscrew the front panel and slip the belt over the front of the drum. Reattach the top front panel with screws and loosen the tension roller from the front bottom access panel. Hook the belt around the motor pulley and tension roller. Tighten the tension roller and turn the drum by hand to make sure there are no restrictions and the belt and motor pulley are turning. It is best to inspect the drum rollers on the bottom of the drum to make sure the rollers have no play in them. If you can wiggle the rollers front to back replace them too. Replace the rest of the panels and check the units operation.
Feb 05, 2010 | Whirlpool Dryers
Crescent-shaped burns on clothes from dryer
Hello Friend, Your problem is very simple to fix. You need to replace the Rear drum support rollers. To replace the Rear drum support rollers just remove front of dryer body exposing the drum, look under the drum and you will see the belt and tention wheel in front of the motor. Now, release the tention on the belt and remove belt from motor shaft. At this point you can remove the drum up and out of the dryer cabinet. Look towards the rear of the dryer cabinet and you will see the rear drum rollers. The roller on the left has a support strap held on by a press on clip. just pry this clip off and remove support bar. Now there will be a plactic triangular clip holding the roller in place. Just remove the plastic clip and replace roller. The roller on the right just has the triangle plastic clip just remove and replace that roller as well. Be sure to lubricate the roller shafts with some 3 in one oil prior to re-installing the new rollers. Make sure you re-install all of the retaining clips. After re-assymbly of your dryer if should run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks.
Dec 29, 2009 | Kenmore 63942 Dryer
We are trying to replace the belt to our front loader dryer DLE5977W and are not sure how to take the dryer apart. Do we start from the front or the back.What steps do we need to replace the belt. Thank...
If it is a front loading machine:
You would remove the front of the machine, that will expose the drum and belt, remove the drum and belt and that will expose the drum rollers,motor, idler arm pulley.
Before you replace the drum and belt assembly, Check you drum rollers for flat spots, If they have flat spots on them replace them. I would also recommend that you lubricate your drum rollers with a good quality of machine oil such as 3 in One Oil. This will save you later on another disassembly because of noisy drum rollers.Apply the oil at the shaft of the drum rollers.
I hope this helps
Oct 04, 2009 | Dryers
Griding noise while spinning. the unit heats and spins but makes grinding noise as if the drum were off track
Jun 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
My Maytag dryer Model DE308 is very noisy. sounds like something is catching or grinding. can I fix this?
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both types
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one,
if the dryer is the open drum type,
Oct 17, 2008 | Dryers
Epic 425 Mx Treadmill EPTL88105 ! Logo
63 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
