Question about Makita RST210 2 Stroke Petrol Line Trimmer 21cc
How to thread line onto reel? - Makita RST210 2 Stroke Petrol Line Trimmer 21cc
I have the 1276sli abumatic spincast reel. The issue is when am reeling the line in there is bump in the handle always at bottom as i crank the line in under load.
Hey michael,
Sometime when you add line to a spincast reel, where you tie the knot and wind line onto the reel, it makes a bump in the spool, this "bump" in the spool sometimes hits inside the reel everytime it makes a rotation....
May 18, 2017 | Fishing
String only comes so far when you shoot has enough line no knots or anything seems like its getting caught on something
unreel the line and hold tension on it when reeling back onto spool some lines dig in worse than others .
Sep 07, 2015 | Zebco 808 Bowfishing Spincast Reel 808...
Trying to wind the bobbin on my singer 6268 but the thread keeps winding under the bobbin. What am I doing wrong?
if the bobbin winder is driven of the end of the machine then you may have to guide the thread as it winds onto the bobbin
if you are allowing the thread to come directly from the reel and it is not in line to the bobbin then what you have is what will happen
Jul 21, 2015 | Singer Sewing Machines
How to take reel apart to reload line
Hi Karen:
If this is a fishing reel, pull off the old line into a plastic bag or wind it on to an old spool so it can be safely discarded. Tie the new line on to the reel, and wind the new line on.
There used to be a closed face spinning reel that you would unscrew the face cover to access the spool.
If this is a weed eater, grass whip, some of the older units had a threaded centre with a left hand thread. Once unscrewed, the spool lifted off and you could wind on the new cutting cord.
Happy fishing, or gardening.
May 14, 2015 | Sport & Outdoor - Others
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do you put line on a magda pro star reel
Mount your reel on your rod. Run the line from your filler spool thrthrough the bottom guide of your rod. Pass the line througo the line guide on your reel and tie your line to your reel using an arbor knot. Put a pencil or dowel rod through your filier spool and have someone hold light tension on the spool as you reel line onto your reel.
Aug 03, 2014 | Okuma Magda Pro Linecounter Magda Pro...
With TEAC A-2300s. Install new tape from supply side to take up side.
It goes from the left reel over the tension arm under the stationary guide in the head stack under the lifters between the Pinch Roller and Capstan shaft and then under the rigfht tension arm and threaded onto the reel. This is from memory but I am sure I have threaded 1000 or more decks in 40 years of service.
Sep 01, 2011 | Teac Audio Players & Recorders
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
Is there a trick to rewinding a new recoil rope on a Tecumseh 4 stroke so that it rewinds properly and tightly?
It's not too bad, but it takes patience. Determine the desired length of the pull cord. You normally do this by placing as much of the old rope together as you can and then measuring it. Obtain the proper diameter line from your dealer, or a big box store. Put a knot in one end of the pull cord, and make sure that the other end isn't fuzzy, as you will be threading that end through the reel and shroud hole. An easy way to prep the line is to light the end with a lighter until it melts, then touch it to something and then pull it away slowly. This will leave you a fused end with a taper on it. Remove the shroud. With the shroud off, wind the reel tight. While holding the reel under tension with one hand, thread the tapered end of the line through the reel and out the hole of the shroud. Pull the line all the way through, and seat the knot. Place a knot about 6" from the end on the tapered end that you passed backwards through the shroud. If your pull cord passes through an eyelet on the handle, away from the shroud, thread the line through this before tying the knot. Slowly, release the pressure that you've been holding on the reel, and allow the reel to feed in the pull cord. The knot will not allow your line to be retracted fully into the shroud. Install the handle, and untie the knot in the line. Reinstall the shroud onto the machine.
Hope that this was helpful. You may rate this solution, if you like.
Best regards, --W/D--
Jan 25, 2011 | Tecumseh Enduro Horizontal Engine 5 HP...
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Makita RST210 2 Stroke Petrol Line Trimmer 21cc Logo
23 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
