Question about Carrier Heating & Cooling
Need wiring diagram for 1980's 3 ton package unit
My 70y old dad wants me to take 2 carrier 3 ton package units and make a good one. the wire diagram is gone on both units i was electrican, comerical new buildings, he started with out me and unpulged and moved motors, coil ,transformers i just need a wire diagram were all wire's plug in to
  • Reeferman
    Reeferman May 11, 2010
    Model numbers might help!
    Guru:
  • 462 Answers
I assume you know if this is correct voltage and single or 3 phase, and whether it will fit your application or not, how is the duct work going to attach, how many people will be in the conditioned area, what is the building made of, how much insulation is has...
A little more to it than just "turn it on".
If you get the models and serial and can contact the manufacturer or their representative you might get a wire diagram. Most any package unit would do. As long as you keep the original equipment controls. If you "patch" it up it may be hazardous by not having safety's where it was designed for. Or for instance It may have a anti freeze thermostat. By passing this could lead to coil freeze up and compressor damage. Leaving out a pressure switch (if any) may do the same or could become dangerous to people in the event of fan motor failure. A low temperature fan speed switch may not be needed now unless you plan to run the AC in below 55'f.
And a few dozen other factors that might need to be considered.
If you feel confident after this then contact carrier.
Please rate me as high as you can and thanks for using fixya.
Posted on May 19, 2009
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
12 ton carrier package unit wiring diagram
heating or cooling mode? The wireing diagram is on the back of the electrical access door.
Jan 26, 2014 | Heating & Cooling
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
I need Hitachi RUA-30AT3S wiring diagram. This is a self contained air conditioner. Rats damaged all wires while it was in store. I have no clue about re-wiring.
FSM Forums • View topic - Hitachi Air Conditioner ManualsHitachi Air Conditioner Manuals - looking for Operations & Maintenance Manuals, ... RUA 30AT3S (Package 30 Tons) RUA10AT3S (Package 10 tons) ...
www.manual-directory.com/forum/viewtopic.php?f=10&t=2453...0 Hi, although your unit is a 2 1/2 ton, you will be able to get a manual showing you the correct wiring diagram using the model number you supplied. It shows your model above. This is the only way to get a diagram for this unit. Please keep me posted on the out come or if you need more help.
Sincerely,
Shastalaker7
Apr 03, 2010 | Heating & Cooling
Wiring instructions for Thermostat Honeywell with Carrier Package
Jumper R to Rc and hook hot wire from transformer to R usually red wire
O = Reversing valve probably white or orange If you get heat when calling for cool or Vice Versa then switch wire from O to the B terminal.
Y = Contactor usually yellow
G = Blower usally green
Jumper Aux to E need to go to unit and use the wire that goes to your Auxiliary or 2nd stage heat
L = Light if you have this terminal on your unit then hook it up.
C = Common from transformer usually black, if you have this terminal on your unit hook this wire up.
Make sure you go to your unit and only hook these wires up if they go to these locations.
Jan 11, 2010 | Heating & Cooling
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
Heating & Cooling Logo
538 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
