Question about Maytag Performa PAV2200
Whirring noise on spin cycle
As soon as spin cycle picks up speed a constant whirring sound not unlike a dry pulley spinning but not shrill like metal on metal. Stops immediately when tub rotation stops.  Operates normally in all fuction except for noise.
  • Anonymous Mar 19, 2014
    sometimes when in spin cycle shrill sound
  • 60 Answers
I have had this problem before you need to repace the tub bearing assembly which reqires special tools to do the job and the whole unit needs to be torn apart
Posted on Oct 19, 2007
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
Clunking/thumping with spin cycle, reduces as spin speed increase
It's hard to tell without looking at the washer. But my first response would be that the transmission is wearing out. Inside the plastic cover for the adgitator is a metal drive stem. This assembly has a pulley on the bottom where your motor attaches to; inside the bottom of your washer. It is quite common after many years that these go bad. Have you ever noticed unexplained grease or other stains on your clothes after they came out of the wash?
Apr 22, 2010 | Maytag Washing Machines
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Whirring noise in spin cycle, 7 year old machine
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Oct 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
182 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
