Question about Texas Instruments TI-5019 Calculator
Do not know how to put paper in - Texas Instruments TI-5019 Calculator
Don't know where to put the paper
What paper are you on about? motherboards don't use paper.
Nov 28, 2012 | HEWLETT-PACKARD 5188-7535 Motherboard
No problem, but don't know if the print goes face side up por down into the printer when faxing
Where you put the paper must be a little icon like a page with lines, if you see this put the paper face up. I am surprise you did not check with a fax recipient to see if they got it (Blank paper or the fax)
Mar 18, 2011 | Office Equipment & Supplies
Printer keeps saying that we are out of paper even though photo paper is in and glossy side is down. Can't figure out why it isn't sensing that the paper is there.
Go into printers and faxes, right click on your HP PHotosmart printer, click on properties, in the general tab click on printer preferences, on the advanced tab make sure the paper type is Automatic so the printer will acknowledge any type paper put into the tray.
This may allow the printer to see your photopaper. Also try to remove the paper completely and put it back in the tray, make sure the paper is pushed all the way to the front of the tray.
Let me know if this answer is helpful. Let me know if you have any other specific questions, if so, add as much detail to the problem as possible.
Thank You,
Brian
Feb 26, 2011 | HP Photosmart D7160 InkJet Printer
Paper feeder won't feed...
make sure the paper select is from the tray were the paper is if you dont know put paper in top & bottom tray and see from where the paper is pulling. Note! dont put more than 5 papers at a time when testing it.
Good Luck!!
Please rate me good.
Jul 14, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
I do not know how to the put the paper into the printer
1). fan the paper
2). there is a paper tray under neath the conrol panel. flip up the cover, pull out the extender.
insert the paper short side in (8 1/2 x 11)
3).squeeze the slide paper guides on the side of the paper tray rest against the edges of the paper.
4).puhs in the paper entender, lower the tray cover.
5). entend the paper exit tray stop on top of the paper tray tocatch the paper as it exits.
Nov 13, 2008 | Dell 946 All-In-One InkJet Printer
No paper fed
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
Jul 23, 2008 | Lexmark E234 Laser Printer
How to feed the printer with paper
its very easy to do it put your paper in the bottom tray ad then select the option to print its done!!
Feb 09, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Canon iP6000D - reads "No paper"
Unfortunately I don't know how to fix it but I do know how to get around it. Or at least on mine I do. My printer does the same thing to me even though I have plenty of paper. I've just kept inserting paper into the printer until it finds that "level" that it needs to say it has paper. If you find that level you can either continue putting in paper from that level on or put something underneath the paper like a way to keep the paper high enough so that it reads it properly. I know it's not a solution but it's a loophole of sorts.
Apr 29, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Texas Instruments TI-5019 Calculator Logo
35 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
