Question about Sanyo DS32224 TV
3 DIGIT CODE FOR SANYO REMOTES - Sanyo DS32224 TV
2 Suggested Answers
  • 879 Answers
SOURCE: 3 digit code of SANYO
004/ 013/ 049/ 108/ 110/ 180/ 209
Posted on Jun 14, 2012
Can you give me the codes for a sanyo tv for a universal remote
try this link...4 digit GE codes for TV sets including LCD, Plasma, and Panel TVs Brand Code SANSUI SANTECA SANYO SCOTCH 224 more rows
4 digit codes for TV sets including LCD, Plasma, and Panel TVs - GE ...
www.eliztech.com/remotes/ge-4digit-tv-codes.php codes for sanyo tv for universal remote Google Search
Dec 09, 2016 | Sanyo Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Wat is tha apex DT502 code to a Sanyo TV remote?
Jakki. apex DT502 code. 749 or 0749 or 00749 depending on if your remote uses a 3,4, or 5 digit code. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://electrohelponline.blogspot.ca/ http://www.remotecodelist.com/ Codes for Universal Remotes How to Program Universal Remote Welcome to Remote Central Universal Remote Control Reviews More
Apr 14, 2015 | Sanyo Televison & Video
I need the codes to a sanyo tv and i have a brightstar br100z remote
The Sanyo codes appear to be 620, 801, 931 . Turn on the TV, press and hold Set-up until the light comes on and enter the three digit code. Check if the TV responds (volume, channel). If not try the next code.
To search all codes: turn on the TV, press and hold the Set-up button. Then press Channel + slowly but repeatedly until the channel changes. Press Enter (if you overshoot, press Channel - to before pressing enter.) To record the code, turn on the TV, press and hold Set-up, then press Set-up again and type 0-9 individually until the indicator light blinks. That is digit 1, repeat the search from 0-9 for the other two digits.
If your TV was released ~6 months before the remote was programmed or is newer than the remote, then the code you need may not be in the remote's programming. In that case, you need a newer remote, one of the remotes that is programmable (USB to a computer), or a remote specific to your TV (try remotes.com and search on the TV model - leave off the brand name).
I hope this helps.
Sep 26, 2010 | Televison & Video
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
Sep 09, 2010 | Sanyo Televison & Video
Progamming Comcast remote
Go here, it has a viewable manual for the comcast remote and a list of codes. There is also a way to search codes listed. Haven't tried yet, but it can't hurt trying!
http://www.scribd.com/doc/202024/comcast-dvr-remote-manual
Sep 08, 2008 | Sanyo DS20930 20" TV
Sanyo DS32224 TV Logo
27 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
