Question about Westinghouse Televison & Video
Direct tv remote code for westinghouse dw37h1g1
SOURCE: Direct TV remote, need code for Westinghouse Flat Screen 32" itsdon458@yahoo.com
11100 worked for me!
Posted on Apr 07, 2009
pabloloco
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Oct 16, 2009
frankzcomput
  • 268 Answers
SOURCE: DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
Posted on May 23, 2010
danbusa
  • 185 Answers
SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Posted on Apr 19, 2011
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
BeckiB_DISH
  • 286 Answers
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Posted on Apr 21, 2011
How do I turn off a westinghouse tv with a direct tv remote?
Hello Deborah Ingram,
Direct TV remotes have special instructions to "program"
various Television manufacturer's equipment into each of their units. Simply by inputting the appropriate codes the "TV"
Once PROGRAMMED they will operate the set and the "DIRECT" equipment together...
Typically some fine set "MENU" items will not be available... so it is wise the keep your REGULAR REMOTE around for those SPECIAL APPLICATIONS.
24 hour DIRECT contact information is available:
http://www.directv.com/DTVAPP/content/remote_codes2 Remote Control Code Lookup
Dec 26, 2016 | Westinghouse Televison & Video
How to turn off a Westinghouse tv using direct tv
You must program the remote to your set type
(check your remote in the upper left top corner)
Instructions and 24 hour assistance are available from DIRECT
DIRECTV Universal Remote Genie TV Remote
Cual es el codigo de acceso para canales de tv LD-2240
Codes are stored in the remote. A Westinghouse remote should be able to control your TV directly. If you are using a universal remote, you will have to perform a code search to find something that will work.
Jan 15, 2016 | Westinghouse Televison & Video
Westinghouse tv DW37H1G1 Problem has sound, black picture
how old is TV , Is it Plasma or LED . Plasma Is supposed to only last 3 years
Sep 29, 2014 | Televison & Video
Can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Try these codes listed for Sony.  10080 11100 10111
 One of these should work.
Jan 06, 2008 | Westinghouse 16093 Remote Control
Remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Nov 10, 2007 | Westinghouse 16093 Remote Control
Televison & Video Logo
112 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
