Question about Ovens
The bottom element is not working on my Delonghi D906 GWF oven
The bottom element on my Delonghi D906 GWF is not heating
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
    I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
    318022002 is the part number for the relay board with transformer
    318022001 is the part number for the relay board without transformer
    Yes the one without the transformer is more expensive for some reason.
    The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
    To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
    NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
    Posted on May 13, 2009
    • 13 Answers
    SOURCE: Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Posted on Jul 29, 2009
    My delonghi oven is making a ticking noise and with all the switches turned off it's is still heating and rather hot. Won't turn off and cool down
    Sounds like an improperly grounded element in the circuit... If an element or wire makes contact with the metal frame and welds itself in place, the electrical current can BYPASS the control and heat uncontrolled- throw the circuit breaker to interrupt the power.
    A thorough inspection must be made of the elements and wiring.
    Help Me Find My Model Number
    Dec 12, 2016 | DeLonghi Ovens
    Tip
    Delonghi Oven not heating? How to replace a Delonghi fan oven element
    This video will show you how to replace fan oven element in your
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    on Jan 30, 2014 | DeLonghi Ovens
    Maytag oven won t heat up
    the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
    May 07, 2014 | Maytag Ovens
    I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
    if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
    Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
    Noisy oven
    Make certain that the heating element is properly seated WHEN THE OVEN IS COLD! When you put "current" through wires and heating elements, they vibrate. Zip tie the wires together outside the oven cavity.
    Apr 25, 2009 | DeLonghi Ovens
    Bottom Element Open Circuit & Fan Element not working
    No resistance in a bake element is a bad element. Replace it.
    Most fan come on with a rise in heat. No heat/no fan.
    Apr 08, 2009 | DeLonghi Ovens
    Delonghi range oven
    Bake- Normal convection- both upper and lower heating elements.
    Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
    Broil- radiation- The heat is radiated by the ifrared broil element.
    Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
    Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
    Ovens Logo
    41 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
