Question about Canon PowerShot SD600 Digital Camera
Both these disks say error when put in printer to download and say locked when put in the camera, have moved the lock on the side with no luck.
I have two flash cards, 4GB SanDisk and a 4GB Edge, and I get an error message when I Put them in my printer to download and also in the cannon camera. Have other cards and have never had this problem, have moved the lock on the side and tried that, no luck. what's the deal?
  • Canon Master
  • 4,738 Answers
Have you ever formatted your cards in your camera? If not, that likely is your problem. They may work fine at first, but with time corrupt. Try formatting these cards in your camera, but note that this will also totally erase these cards. To format, put the cards in the camera, go to the "tools" menu, and select the item stating your cards memory capacity. Then follow the prompts to format, making sure that "low level format" is checked.
IF there are pictures on the cards that you don't want to lose prior to formatting, please see the following for some excellent freeware recovery software that you can use with your printer's card reader. AFTER you download your pictures with this software, then consider formatting:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
Posted on May 20, 2009
When I insert my pny optima sdhc 4gb into my olympus camera it says write protect and I can't use the camera. It has worked before so what is wrong with it?
SD cards have a slide lock switch to enable/disable write protection on one side. Check if you flipped the switch to the locked position when you put the card into the camera. (The switch will be on the left side of the card. That's the side without the angle cut out.) It's locked when the switch is towards the contact area that goes into the card slot. When you put the card back into the camera, use care to avoid accidentally moving the switch. If the switch moves very easily, you should probably replace the SD card. In that case, sometimes the lock will enable as the camera is moved.
If that doesn't help, copy the pictures that are currently on the SD card to another device. Then try to reformat the card. (You may need to try to reformat it on another device. Put the card into a card reader on your computer. Then use the Disk Management commands on the computer. For Windows XP and later, this can be found under the System and Security Control panel near the bottom of the page.)
If the lock switch has been damaged, you may be able to temporarily disable the lock by trimming any remaining plastic from inside the lock groove and then covering the groove with Scotch tape or a similar product. (Make sure not to cover the contacts or leave the tape lumpy enough to keep the card from fitting into the card slot.) Plan on replacing the card soon.
I hope this helps.
Feb 25, 2014 | Cameras
Card locked.
What kind of card is it? Some different cards have a physical miniswitch on the side. Maybe you moved it by mistake to the 'lock' position when handling it. Also, some cameras have a lever inside the slot where the card fits, this lever locks/unlocks the physical switch I was talking about, and it can sometimes move to an undesired position, namely always locking the card. Look into the slot and try moving gently any lever/protusions.
Nov 21, 2013 | Canon Cameras
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Apr 07, 2010 | Canon PowerShot A75 Digital Camera
The card is locked. error
Move the slide switch on the side of the card.
Nov 22, 2009 | Casio Exilim EX-S500 Digital Camera
Niken coolpix digital camera
Hi there and welcome to FixYa.
Check your card, there is a little switch on the side of the card. One side says locked and the other side says unlocked. Move the switch to unlocked and put it back in and try it again.
Rob
Mar 04, 2009 | Cameras
Memory card locked
pull the SD card from the the slot and it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jan 11, 2009 | Toshiba PDR-3300 Digital Camera
How to unlock card??
Hi
there should be a little switch on the side of the memory card to lock and unlock it.
Keep us posted.
Jan 11, 2009 | Lexar Professional High-Speed 2GB Secure...
Locked
Look on the side of the card. There is a little switch. When you took it out of your camera you must have bumped it into the Locked postion. Just move it in the other direction and you should be set.
Good Luck.
Apr 08, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Memory card error/card locked
It sounds like your card is locked. You need to unlock it. On one of the sides you should see a piece that can move back and forth. Move it from the position it is now to the other side. This should unlock your card. When locked the files are unaccessible to anyone. This also means that files on the SD card cannot be deleted while the switch is in lock position. When the switch is in up-position, then all files located on the card are accessible to anyone, and that files may be deleted from the card.
Good Luck.
Apr 07, 2008 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot SD600 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
