Question about Garden
Husqvarna 235R ignition coil problems - Garden
3 Suggested Answers
  • 13 Answers
SOURCE: ignition coil
Here you go. If the price seems high there are likely several more to be found on this page. Good luck with it.
http://cgi.ebay.com/36-136-137-41-141-142-HUSQVARNA-SAW-IGNITION-COIL_W0QQitemZ270389321883QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef475a09b&_trksid=p3286.m20.l1116
Posted on Jul 16, 2009
  • 2239 Answers
SOURCE: I need an exploded view of a Husqvarna 235r
Send me an e mail address and i will send you a pdf file with the parts list on
Posted on Feb 29, 2012
Husqvarna 235r brush cutter starts fine when cold but won't start when hot
If it has spark and fuel then it may be worn, causing low compression and too weak to start. .
Jun 15, 2014 | Husqvarna 323R 24.5cc Straight Shaft Bike...
There is a simple test you should do on this unit. first remove engine cover, then remove spark plug, then take soapy water and spray it around the base of the cylinder where it meets the crank case, if you have compressed air and a air gun, shoot air through spark plug hole and watch for bubbles around base of cylinder. be careful to only shoot very low pressure into unit. if you see bubbles there is an air leak, this is not repairable. new unit.
Jun 15, 2014 | Husqvarna Garden
Husqvarna 235R Manual The fuel lines on my 235R disintegrated. I have cut new ones from the right sort of tubing but cannot figure out where to route them to prevent fouling other parts. Is this shown...
The fuel hose from the tank goes under the carb to the left hand side of the carb and in front of the two feet on the bottom of the air filter housing, it is all a bit tight under there, the right hand pipe goes from the carb to the shorter connection on the primer, a pipe from the longer connection on the primer goes back to the tank
Oct 09, 2013 | Garden
I have a husqvarna 235r it starts without the mufler but when i put the mufler it wont
Possibly a blocked spark arrestor or carbonizes exhaust, probably needs cleaning out as the gasses cant flow through the exhaust properly.
Aug 01, 2013 | Husqvarna Garden
My husqvarna 235r runs without mufler but i put the mufler and it wont start
Possibly a carbonised exhaust. probably needs a clean
Aug 01, 2013 | Garden
Feb 28, 2012 | Garden
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
After running for a little while the blower keeps cutting off.How do i fix this problem?
needs a new ignition coil..it's electronic and is affected by heat...the new one's don't have that problem...
I'll be waiting for the "how to change my ignition coil" post...and i'll help ya there too...
Apr 18, 2010 | Husqvarna Backpack Blower, Model No. 356bt
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
