Question about Husqvarna Viking 1
Husqvarna Viking E20 machine stuck in reverse
  • 87 Answers
SOURCE: Husqvarna Viking #1 blown fuse
Contact Ron at A1, he sells Husq Viking and can even email attach a PDF parts list to you.
http://www.a1sewingmachine.com/parts.html
Posted on Apr 28, 2008
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
  • 8 Answers
SOURCE: Need manual for Scandinavia 200 sewing machine
I have one.
Posted on May 25, 2009
  • 152 Answers
SOURCE: Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Posted on Oct 07, 2009
SOURCE: Husqvarna Viking Sewing Machine 6020 sews in reverse
The grease in the reversing mechanism may have turned to 'glue' as in my Viking . I used a hair dryer to soften the grease , and then oiled it.
Posted on Feb 10, 2010
How to fix a Husqvarna sewing machine 2000SL 6460 stuck in reverse
A machine stuck in reverse usually means the step motor controlling the movement of the feed dogs has gone bad. You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Sep 05, 2014 | Husqvarna Sewing Machines
Stitch length not working and sticking in reverse
sounds like it needs servicing and cleaned. Suggest only using authorized husqvarna viking dealer for service. You can find your local dealer at the Husqvarna Viking website http://www.husqvarnaviking.com and selecting "dealers" link.
Feb 11, 2010 | Husqvarna Viking 1
Machine speens but not the needle...
Sounds like the motor belt has come off the machine. It needs to be serviced by an authorized husqvarna viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 15, 2009 | Husqvarna Viking 1
Machine sewing backwards only
If you machine was recently serviced, the service tech might have reversed the motor connections. If not, it could be the zero feeding mechanism is stuck. Try dropping your feeddogs, i.e. like sewing on a button. Then raise your feeddogs to see if the problem clears. What happens when you sew a buttonhole using the automated buttonhole accessory? If these do not work, it may be your pc board which has a 5 year warranty if you are the original purchaser from an authorized Husqvarna Viking dealer. If resetting feeddogs does not clear the problem, Will probably need service by an authorized Husqvarna Viking dealer. If the service tech cannot repair, they can send to Husqvarna Viking Service Technician for repair. Visit the Husqvarna Viking website for a list of dealers closest to you. http://www.husqvarnaviking.com/us Good luck.
Sep 23, 2009 | Husqvarna Viking 1
Stuck in reverse too!
There are some 3rd party vendors offering parts -
http://www.pd60.net
http://www.sewingpartsonline.com
I would recommend taking it back to your local authorized Husqvarna Viking dealer and have them send it to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for repair. They may be able to rebuild the part or get one off an old machine being used for parts. A list of AUTHORIZED Husqvarna Viking dealers is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Jul 01, 2009 | Husqvarna Viking 1
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
Viking Husqvarna 1610 sewing machine won't go in reverse
Check with an authorized Husqvarna Viking dealer. Check Husqvarna Viking website for dealer closest too you.
Feb 26, 2008 | Husqvarna Viking 1
Stiching prob. Help! Vking husqvarna model 6020
Sounds like the feeding unit is stuck rather than the button. The reverse button engages the feeding unit. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Dec 08, 2007 | Husqvarna Viking 1
Husqvarna Viking Sweden Model 6030
On all sewing machines there is a button or lever which makes the machine go backward. The button could be stuck, if so put a drop of oil on it and try to release it. If there is a lever that has been raised which puts the machine in reverse, simply lower it to the lowest position. This should solve the problem.
Zelma
Nov 29, 2007 | Husqvarna Viking 1
Sewing Machines Logo
115 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
