Question about Dishwashers
FRIGIDAIRE DISHWASHER & INSINKERATOR DISPOSAL
I USE THE DISPOSAL FREQUENTLY, IF I DON'T USE THE DISHWASHER FOR ABOUT 2 WEEKS I GET A RANCID SMELL FROM IT EVEN IF I LEAVE THE DOOR OPEN. COULD THE DISPOSAL BE LEAKING BACK INTO THE WASHER?
THANKS RICH
  • 90 Answers
Sounds like your waste pipes aren,t connected properly.You need a water trap (u bend) between the dishwasher and the main waste pipe from the sink. Any decent plumber should be able to fix in less than an hour.Cheers Derek.
Posted on May 19, 2009
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
Frigidaire dishwasher stinks. It is a brand new one FGHD2433KF and we just moved into our brand new home1.5 weeks ago. The sink drain does not smell. There doesn't appear to be any water in teh...
Hello, dp
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Sep 10, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
I forgot to open the dishwasher hole when installing. I don;t have the instructions and I can't figure out what I am supposed to do. It seems solid and I don;t see anything removable
If you disconnect the dishwasher hose from the disposal and peek inside the disposal where the hose was, you'll see that it's blocked by a piece of plastic. It's premolded into the inner chamber but that portion is breakable. Stick a screwdriver or something into the hole and give it a whack. If that piece end up inside the disposal's main compartment, you'll need to get it out. You could turn the disposal upside down if you haven't already installed it, but you did.
Aug 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I installed a new dishwasher and now my insinkerator disposal has no power? What happened?
That is strange did you hard wire d/w or simply plug it in.did you trip the gfi.need more to go on.There is a reset on the bottom of disposal a red button push it it should click might need reset.
Apr 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Where is the reset button on the InSinkErator Badger 5, 1/2 HP Garbage Disposal Problems & Solutions?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Jan 23, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher does not seem to drain completely. The water becomes rancid smelling.
be sure the screen under the botton spray arm is free of food particles. You may need to remove it to clean it. Make sure the drain hoses are not kinked.If this doesn't help the problem, you will need to pull the dishwasher and disconnect the drain hose from both ends and flush out debris at the sink. You may need to replace the drain valve
Sep 18, 2010 | Frigidaire 24 in. PLDB999S Stainless Steel...
UNsermount sink with waste disposal
The easy mount disposal has a ring the (sort of) screws onto the insinkerator sink drain - the thing that is labeled insinkerator when you look down into the sink.
If this is a new install on a new sink, I recommend the EZ mount model. If there is already the sink drain (thing mentioned above) labeled insinkerator, you may be able to simply attach the new disposal to the existing drain ring.
Also: If you have a dishwasher to connect, this is a great time to install the "air gap valve" (available for almost free at any hardware store.)
May 05, 2009 | Dishwashers
Foul odor coming from insinkerator disposal
the only thing that should be used to clean a disposal is "Ice" anything else will / could cause several different problems. Run the water for about 10 seconds, turn the disposal on, put a few handfulls of ice down the drain, when the ice is gone, leave the water running for about 20 seconds. This both cleans the unit and sharpens the blades..
Oct 31, 2008 | Dishwashers
Dishwashers Logo
142 people viewed this question
Top Dishwashers Experts
