Question about As Seen On TV Handy Stitch Mechanical Sewing Machine
I have a white sew ez model w338 and it wont sew. Everything seems to work fine but it does not stitch
My brother 546d doesn't sew everything seems to work fine, but fabric comes through unstitched. I took it to a repair place and they said there was nothing wrong with it. But still doesn't stitch.
Did the repairman actually stitch with it--did he create a stitch sample? If so, then it may be something on your end. Make sure it is threaded correctly. Also, install brand new needles.
Nov 13, 2017 | Brother Sewing Machines
How to fix decorative stitches for sewing machine.
Make & Model??? Sounds like the stitch selector mechanism is stuck. If it's a mechanical machine, you can try oiling the mechanics of the stitch selector with Tri-Flow Synthetic Oil and then heat with hand-held hair dryer.
Mar 23, 2015 | Sewing Machines
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother PE770 Computerized Sewing Machine
Using a White model 616 with a twin needle?
singer has a free manual in pdf form for the machine, which can tell you if the machine is capable of using the twin needles
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w616 ) & click search
May 21, 2012 | White Sewing 1866 Mechanical Sewing...
I keep missing a stitch
Skipping stitches can be caused by a bent or dull neeedle or a needle that is not suited for the fabric you are sewing on.
Feb 08, 2012 | Brother LS-2125 Mechanical Sewing Machine
My white rotary model 2221 sewing machine will no longer switch from straight to decorative or zigzag stitching. What can I do to fix it? I have cleaned and oiled the machine and have recently used it...
it's possible that the cams that do the zigzag stitch could be worn or have gotten damaged
it would be a good idea to have it serviced
I would suggest to look in the yellow pages & see what sewing machine repair shop are in your area.
and if you do get it serviced, when you first get it home, sew on it & make sure it works correctly, they normally have a 15 to 30 day time limit for you to check the machine out & making sure it works ok, & make sure that you don't just pay for a cleaning..
Sep 11, 2011 | White Sewing Sewing Machines
I purchased a White Sew E-Z Model W338, 3days ago, and I cannot get the bobbin thread to come up with the spool thread so that I can use the machine.
We had the same issue. The needle was facing left/right instead of front/back. Once I unscrewed the needle and repositioned it so that I could thread it front/back, I was able to get it to catch.
Nov 04, 2010 | White Sewing Sew Cute SC20 Mechanical...
Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
Mar 23, 2009 | Husqvarna Viking 1
Brother mechanical sewing machine XL-5060 - Can't select stiches
I have been provided with the solution by Brother.
If I turn the Stitch Length dial to "SS" I can select stitches from 10 onwards.
Wish they could have put that in the manual!.
Jan 18, 2009 | Sewing Machines
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
As Seen On TV Handy Stitch Mechanical Sewing Machine Logo
42 people viewed this question
Top As Seen On TV Sewing Machines Experts
Tally Girl
Tally Girl
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
