Question about GLD Viper 797 Electronic Dartboard
Viper dartboard error 01 shows up on screen and after turning off then on leaves then immediately comes back
What is the bluetooth pin code for gld viper vtooth 1000 dartboard
This website can't help with this information. Please contact VIPER. Please post your question once only.
Jul 21, 2017 | Viper Cell Phones
Viper vtooth 1000 blurtooth pin number
We have no way to know this number.
When the dart hits it momentarily shows the score and then deletes the score with a verbal "miss".
Buy a dartboard that has no electronics. On these devices the dart stays in the place it arrives at and you can read the numbers on the board to see what the score is. This is far cheaper than repairing or replacing your electronic dartboard.
Dec 20, 2013 | Viper Eclipse Electronic Dartboard"
Where do I Connect the AC adapter on a Viper Dartboard
If its the same one shown next to question its on the lower right corner as you look at the board I use to have one like it.It also uses batterys if worse comes to worse
Apr 11, 2012 | Viper Gld Viper 787 Electronic Dart Board...
What transformer will work on sportcraft electronic dartboard
The Sportcraft dartboard transformer that I have shows the following data:Model No: D9 - 10Input: 120V 60Hz 25WOutput: 9VDC 800mAHope that helps
Jan 22, 2012 | Sportcraft Multiple Lighted Electronic...
I turn on the phone to immediately find a pop up that says uncaught exception index 4>=4 then by its self it will go to w white screen that says app error 523 with a reset link beneath it. ive tried...
i turn on the phone to immediately find a pop up that says uncaught exception index 6>=6 then by its self it will go to white screen that says app error 523 with a reset link beneath it
Aug 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
Viper remote start 01 ford explorer.. will only start w/remote
I believe that the 01 explorer use a 'PATS BYPASS " module that may be diconnected somewhere under the dash....
Mar 23, 2009 | Viper Security and Remote Start System...
GLD Viper 797 Electronic Dartboard Logo
88 people viewed this question
Top GLD Sport & Outdoor - Others Experts
Are you a GLD Sport and Outdoor - Other Expert? Answer questions, earn points and help others
