Question about Health & Beauty
Invacare m41bb wheel chair wont power up batteries have 17.4 charge on each
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
  • 10865 Answers
SOURCE: My brother-in-law's chair has a new battery and he
Contact the person who sold him the battery as it is under warranty. That person should be able to check out that battery for you.
Posted on May 02, 2009
  • 175 Answers
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
Posted on Jul 09, 2009
  • 103 Answers
SOURCE: Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
Posted on Nov 16, 2009
  • 692 Answers
SOURCE: Wheel chair won't move. Batteries have been
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Posted on Aug 22, 2010
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
Invacare battery charger 24 volts no output if not connected to battery?
If the battery has stood for two years with out a charge it will no longer be able to hold a charge renew it . most modern chargers need to detect battery voltage before they will charge .
Sep 17, 2014 | Health & Beauty
Invacare what does it mean when light on charger continually blinks red when charging, It wont move
The red light is the power light and if the red light is blinking the charger is bad or the wiring is bad on the chair or the batteries are bad. Usually it's the charger.
Aug 12, 2014 | Invacare Supply Group Pronto M61 Standard...
When I turn my wheelchair on a service indicator light at bottom of joystick blinks 9 times. How do I fix this?
If: Battery indicator flashes the charge level is low
immediately after recharging.
Then it is a. Weak Batteries.
b. Charger malfunction.
c. Electrical malfunction
Solution a.Replace batteries.
b. Replace charger. Contact Dealer/Invacare.
c. Contact Dealer/Invacare.
I got the above from the manual. The link is:
http://www.invacare.com/doc_files/1125085.pdf
Regards
Chellakumar
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
How would tilting the chair cause it to stop operating?
Look for safety features when chair tilted, damaged safety inclination limit
May 28, 2014 | Invacare Nutron R51
I need to replace the fuse for Pronto M41 the fuse is 75A, the wheel chair was not staying charged so we took the battery out to have them checked and they told us to add water then let it charge over...
you are not to open and add water to your batteries they are supposed to be sealed. if you put unsealed batteries in your chair then you did not put in the correct batteries. Batteries from wal mart or any type of unsealed batteries will void any warranties on your chair. the fuse should not have blown if the batteries were put in correctly and you had the wrong batteries. You will have to contact Invacare directly to order a fuse or have a local provider order one for you. While your at it dump the batteries and purchase the correct batteries for your chair You need 2 U1 sealed deep cycle batteries. Check with a local interstate battery outlet or contact your provider to get you the proper batteries
Mar 30, 2011 | Electric Mobility Invacare Pronto M41...
Batteries not charging
This is a manual wheel chair, there are no batteries. If this is not wheel chair you are asking about, the batteries may need to be replaced. They can become damaged if they have been stored or sitting unused for a while.
Aug 10, 2010 | Invacare Supply Group 19 in Steel...
When should i charge batteries, should i plug in everyday even if not using my power wheel chair
No.. dont do that.. as that might weaken up your battery and ruin its battery life.. Only charge it when your using it!
May 23, 2010 | Invacare Pronto M51 Power Wheelchair
Batteries won't charge w/ on board charger-+
sounds like blown fuse which is at rear of chair. may be underneath rear cover. this fuse wont keep the chair from working, however, it will keep the charging from working.
May 29, 2009 | Invacare Supply Group Invacare Pronto M91...
Health & Beauty Logo
41 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
