Question about Dryers
LG Model DLE 59775 dryer blowing cold air - Dryers
jsrock516
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
kachbibi1
  • 979 Answers
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
Where is the drain filter on lg 4408dle
Lg Washers have model numbers that start with WM
LG dryers start with either DLE(electric) or DLG(gas)
so check your model number and add comment below
May 01, 2017 | LG Washing Machines
My tromm dle 7177 is blowing cold air and the check filter light stays on
Also check the vent. It is trying to tell you there is no air flow.
Feb 04, 2014 | Whirlpool GGQ8831L Gas Dryer
DLE 5977B ELECTRIC DRYER wont start
On the exhaust is a limit that trips with bad air flow. I think that puppy is resettable:
LG service manuals
Aug 15, 2012 | LG DLE2532W Electric Dryer
My LG DLE 5932w CONTROL PANEL WON'T LIGHT UP AND THE DRYER ONLY BLOWS COLD AIR. COULT THIS BE A BAD FUSE?
Check the 220 volt circuit breaker or cycle it. If on the other hand you have fuses instead of breaker panel, with 220 volt you should have two fuses to contend with and one or both may be blown.
Nov 18, 2011 | LG Dryers
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | LG Dryers
Hi need to order parts were can i get them
Hi
Thanks for using FixYa. You can order the parts from any of these two links:
LG DLE 2532W Parts
LG DLE 2532W Parts-2
Please do rate thesolution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | LG DLE2532W Electric Dryer
LG Dryer displays CL on screen. What to do?
Makes no mention in the manual about a CL error
Apr 01, 2010 | LG DLE2516 Electric Dryer
Doesnt heat blows cold air
well the first thing that should be checked is resetable thermostat..onthejob
Jan 17, 2009 | LG DLE2532W Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
