Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I am not able to open an ODBC connection from my new Acer machine.I am working on a VBScript code,which works fine on a Dell Machine. I am making a DSN less connection. While running the code I get the following error [Microsoft][ODBC driver for Oracle][Oracle] Line (28): "objConnection.Open()". Is there any setting(PC), that I have to alter on my new machine in order to open a connection. Kindly help me as I am in great distress due to this from the past 3 days..
31/5a
Posted on May 22, 2009
HOW TO CONNECT DATABASE TO VISUA LBASIC 6.0
You'll need to instantiate (create an instance of, or an item in memory) what is known as an ODBC connector. You will also need to create a database or have a database to work with - Microsoft Access will work fine for this, alternatively you can use OpenOffice's version of Access.
The code you'll want to use will be approximately
Dim ws as Workspace dim db as database dim strConnection as string set ws=DBEngine.Workspaces(0) let strConnection= "ODBC;DSN=" & DatabaseName & ";UID=" & UserName & ";PWD=" & UserPassword set db=ws.OpenDatabase("", False, False, strConnection)
Apr 07, 2011 | Microsoft Windows XP Professional
Set up disc does not work
Make sure the disc has no scratches or cracks.
Make sure that the DVD/CD drive is working fine.
If it was burned copy, try burning it again at lowest speed.
If it was purchased or acquired genuine copy from microsoft, please call them for replacement.
If it was provided by a Manufacturer, (Dell, HP, Toshiba, Acer, E-Machine)obtain it from them.
Mar 18, 2011 | Computers & Internet
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
I had just added a new keyboard to a Dell desktop machine and was doing just fine until my finger touched what I can only describe as a power (standby) button and the machine appeared to go on stand by....
1. It happen to me one time with my acer aspire, but since the warranty of life top expired already, what I deed is that I open up the back where my hard disk is located, I just remove it and and after 5 mionutes re-attached it again then i turn on the laptop and it works again.
this is only advisable if you know how to access your hard disk and if it's warranty is lapsed already.
Nov 03, 2009 | IBM ThinkPad T20 2647 Notebook
I have a kodak 5100. it worked fine with my dell/windows xp. when i installed it into my new e-machine, it was fine until i plugged in the usb cable, then it froze my computer. how can i fix this?
Try to put an other usb device like a memory stick in your e machine .check if this works fine.Also check the cable that connects your kodak to the E-machine.
May 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Not able to get IP address on Acer laptop
plz reconfigure ur connection's ip to a static ip. plz assign it manually for ur machine
Apr 07, 2009 | Acer Extensa 5620 Notebook PC
Can't get Acer Aspire One on my house wireless net to share files
Make sure the firewall software on the acer allows the wireless connections, try turning the firewall off for a moment and also disable the wired connection.
Make sure the network is safe or allowed most likely firewall blocking.
Mar 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
ODBC
give ur add i want to check it out.
Aug 26, 2008 | Microsoft Windows Server Standard 2003 for...
No power to my dell dimension 4550
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Feb 12, 2008 | Dell Dimension 4600 PC Desktop
Connecting the scanner to a new computer with Windows Vista
If the Acer has an parallel connection and not USB this indicated to me it is an older machine from the Win98 era. In which case it will not work with Vista. Indeed many newer devices do not work with Vista there is a real issue here Check back with Dell on this.
Jun 09, 2007 | AcerScan 620P Flatbed Scanner
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
117 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
