Question about Canon PIXMA MP600 all-In-One InkJet Printer
I have tried to load the printer and it doesn't show in printers & faxes loading from disc. I tried add prtiner and that gets to a point where it asks for Cnmlr.dll. where can I find this? I have tried Driver detective, no luck. help!
  • 33 Answers
What happens when you load the disc? did you finish the setup process?
sounds like it hasnt been installed properly
sorry if this didnt help, please try to provide more details in future please
Posted on May 19, 2009
My printer show Yellow light & Driver not loaded Windowxp pl.give me anserd detail.
start
Printer & Faxes
if HiTi S420 is listed, right click it
properties
advanced
new driver
(follow on screen instructions & point to where the driver files are located)
Oct 04, 2015 | HiTi S420 Photo Printer
Why can't I load any printer drivers?
have you added the printer into the computer in the add a device in the control panel section
if you haven't the wizard will down load and install the driver but there is nothing to send it to unless you have done that first
Jun 17, 2015 | HP Computers & Internet
Where do I load the staples in the machine
Your printer doesn't support automatic stapling, In fact it doesn't support much at all. It is a single funcion printer meaning that it doesn't have fax or scanning, printing only. You would of got it for about $50 right? Sorry but it has no stapler.
Jun 05, 2011 | Canon PIXMA iP1800 Printer
PSC 1210 ALL IN ONE WILL NOT CONNECT TO MY NEW DELL INSPIRON WITH WINDOWS 7 . IT SAYS THEREIS A COMPATABILITY ISSUE?
drivers are no available on website for win 7. wat you can do you can directly connect ur pritner to computer with usb cable you will se message found new hardware. installing device drivers. after some time it will show you message device is ready to use. then click on start. go to start search adn type pritners. then hit enter. it will open pritners windows.
in that window click on add a pritner on top. then select add a local pritner. then it will says select existing port select usb vertual pritner port and hit next. then under manufacturer select hewlett adn packard and under prtiner select psc 1200 series prtiner and hit next. do not share this pritner follow onscreen instruction to finish add a pritner wizard.
Dec 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
The printer prints part of a page from some sites, some site the whole doc and some site a enpty page
solution 1>
click on start go to control panel go to pritners adn faxes or pritners in vista or win 7. then click on add a pritner. add a local pritner then hit next. choose existing port usb vertual pritner port. then hit next. under manufacturer select hp and under prtiners select deskjet 990c. hit next. do not share this pritner. finish add printer wizard. try pritning
solution 2>
click on start then click on run in open box type
%temp% hit enter. in vista enter %temp% in start search and hit enter it will open temp folder with lot of foledr optio0n find low folder adn delete it permanently then restart computer
Dec 16, 2009 | HP DeskJet 5550 InkJet Printer
Scanner problems
This worked for me. You want to start fresh so delete your HP printer in "Printers and Faxes". Also delete any HP software that loaded in Control Panel "Add and Remove Programs". Next in Control Panel under "Add and Remove Programs", the "Add and Remove Windows Components" TAB, check mark the file to add called "Other Network File and Print Services". After clicking next, the extra print files will load. Reload your software/ HP drivers and it should be fine.
Jul 05, 2009 | HP Office Equipment & Supplies
My HP PSC printer won't print at all. It has new ink cartridges and prints off the test page no problem but the printer & computer aren't communicating
Go into Printers and Faxes check to see if the HP has a tick against it
If not right click on the printer and click on make default
Go to properties and hit Test Print
If that fails go back to printers and faxes and delete the HP
Add a Printer in the Printer & Faxes section
And when asked tell it you have a disk , put your driver disk in the PC and let it load
When it is happy re-boot and see it the printer is seen by XP on the start up.
If it does then let it finish and do the Test Print routine again
Jul 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
Cannot get wireless or bluetooth to work with laptop. The software was loaded on. It will print only if connected by usb.
First, make sure that your Printer is setup with the correct wireless information from your wireless router. Once this information has been entered, you should be able to connect to the wireless printer.
Click add Printer, from Control Panel, Printers & Faxes.
Click Add Printer, and than add Local Printer, Create Local Port, TCP/IP.
Print out the network configuration page from the printer, should be under menu.
Next input the IP information into the IP Address field, the Port will automatically be filled in.
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Jun 30, 2009 | HP Photosmart C5580 All-In-One InkJet...
Can not get the drivers for my lexmark 1100 to load o/s vista
Try:
http://admin.utep.edu/Default.aspx?tabid=56
Download the Lexmark drivers here.
Remove your printer from 'printers & faxes'.
Uninstall your printer software from 'add & remove' program.
Disconnect your printer from your computer.
Reboot your computer.
Install the printer software from your download.
Follow the on screen instructions, hook up your printer to your computer.
Mar 01, 2009 | Lexmark Color JetPrinter 1100 InkJet
Canon PIXMA MP600 all-In-One InkJet Printer Logo
140 people viewed this question
old marine
old marine
