Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Have Maxtor external hard drive problem on laptop no seeing USB port but on my desktop no problem when I which over to it. The Laptop which is a HP show not seeing device tried everything
  • 93 Answers
Please try your external hard disk in some other pc and check, and buzz here.. as soon as possible your problem will be solved..
Posted on May 19, 2009
Trying to transfer data from an old harddrive i have (maxtor, diamondmax plus 9 80 GB ATA / 133 HDD) to My HP laptop
Install the hard drive into an USB hard drive adapter case the plug this USB hard drive into the USB port in your laptop. The laptop will see it as an external storage device, open the various folders and copy the files to your laptop.
You can delete any unwanted files off this external USB hard disk and use it for backups and file transfer.
Mar 14, 2013 | Computers & Internet
How to repair the usb port on maxtor one touch 120GB external drive
You cant repair USB its to small to resoldure unless you are PRO, you could take it apart and connect it to a computer or another laptop and pull out the data here is a guide. http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Reusing_the_Maxtor_OneTouch_III_Mini_Edition_Portable_Hard_Drive
Mar 06, 2011 | Maxtor OneTouch III Mini Edition 120GB...
I need to hook my external hardrive up to my Mac and seem to have misplaced my manual. I need specifics on which cables I need to hook up, etc. Is there information online and/or a picture of this so I can...
In general, external disk-drives have one USB cable, running from the unit to any USB port on your computer. The smaller external enclosures have a "laptop" disk-drive inside, which draws electrical power through the USB cable. The larger external enclosures have a "desktop" disk-drive inside, and requires an external AC 110V adapter, which connects to a power-jack on the enclosure.
Nov 01, 2010 | Maxtor BASICS Personal Storage 3200...
Do I need only one cord (usb) to connect to my laptop?
The "physically-smaller" external hard-drives draw power through the USB cable.
The "physically-larger" external hard-drives require an external power-supply (just like a laptop requires an external power-supply).
Check the casing for a plug where the electrical power would come in; if none, then the unit will draw electrical power through the USB cable.
May 31, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My maxtor external hardive is connected and the light is on, the laptop recognizes it (makes that sound when u put in a usb) but no autoplay comes up and when i look for it when i click "my computer" its...
make sure that you plugged in the external HD to a USB 2.0 port. if you are using a desktop. try to plug in at the back of your tower. if you have available usb cable, change it
Mar 26, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't open Maxtor one touch 4 mini
If the external hard disks is plugged to a USB port and is not detected anymore, try uninstalling the USB Root Hub devices in the device manager. They will automatically be reinstalled on reboot and that can help fix detection issues.
But did you look in the Disk Management module of Windows to see if the disk is there? Right-click My Computer and select Manage.
Jan 05, 2010 | Maxtor OneTouch II external hard drive...
2 usb plugs which goes where??? maxtor 120gb external hardrive pn9nx2dc-500
You have what is call a USB POWER Y ADAPTER: this is designed to provide extra current to your USB HDD drive from a second PC USB port. Plug the end with two USB connectors to your PC/LAPTOP and the single-ended plug to your drive.
Hope it helps! Let me know how you go.
Dec 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Non recognition of Maxtor external hard drive to Drive F
have you checked the externals power suppy and usb leads, aslo have you tried it on another machine to see if that picks it up?
Nov 18, 2008 | Computers & Internet
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
96 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
