This is definitely the correct gasket for your model. The new style of gaskets do have that hold-in strip that needs to be (for lack of a technical term...) Smooshed into the door frame. It'll fit, but it does take a little pressure!
Since bells are so cheap, I recommend that you buy a newone. You could try and pull the petalsout using a screw driver but it will not be possible for it to have the sameshape as before.
Clean any items from under the seats there are sensors under them which might have been smooshed. If the light doesn't go away in about 20 mi take to a mechanic to have the restraint system looked at.
sounds like a paper tray is not fully inserted into the machine. Also check for a smooshed piece of paper behind the paper cassette. The cartridge should have nothing to do with the error. Good luck ....
Mine did it too, the LCD part of the screen was "smooshed" because i put it in my back pocket. I believe it is completely broken. Try sending it back into Fujifilm to see if they can fix it?
