Question about GMC Denali 700C Road Bike
How to true a bike wheel - GMC Denali 700C Road Bike
Rear wheel wobbely
Not enough info here. Is it the rim or the hub that is wobbly? If the rim is out of true (and not actually bent) the spokes can be tightened to bring it back into true. If the hub is loose then the bearings need to be adjusted. Either adjustment can be done by your local bike shop for $10-20. A broken spoke can also make the wheel go out of true, this will cost a little more to fix.
Sep 09, 2015 | Huffy 26 in. Cranbrook Cruiser Bike
The back tire is stuck....it wont turn...
There are a number things that could cause your problem.
First place start is with the rim. Is the rim (wheel) true (straight), if it is bent it could have the tire or brake rubbing. If that is the problem you need to true or straighten or have the rim straightened.
2nd place to go is are the brakes too tight? If so adjust brakes.
3rd place to go could be a seriouse problem. Is the axle frozen. To test you will have to take the wheel off the bike. With the wheel loose from the bike see if the axle will turn if not try to loosen the bearing lock nut just a very little (like 1/8 of a turn) did it free up the axle or does the axle bind a little but still turn smoothly? If so Loosen the lock nut a little more. Just enough that the wheel will allow the axle to spin freely but not so loose as to allow the wheel to wobble sideways at all. If the axle turns and grinds and clunks your bearings likely need to be replaced and or greased. Do not just squirt oil into the bearings it is too light and will not last.
I hope this helped, good luck!
Mar 11, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
How do i true my wheel to stem on my mountain bike
there should be an allen key screw at the top of your stem. sometimes there is a plastic cap on top of the screw head, if so you should be able to pry it off to get to the screw. get the right sized allen key, loosen it, true the stem to your wheel and tighten it back up
Oct 18, 2012 | Santa Cruz Mountain Bikes Cycling
How do I change the back rim on the bike?
To change just the rim is a pretty big job, since you would have to remove every spoke and assemble a new wheel. But maybe you are asking how to straighten the wheel? If the bend is a bit of a wobble, and not a sharp kink, then you can usually true-up the wheel by adjusting the spokes. If this happened kind of suddenly, then you probably have a broken spoke. Pull on every spoke one at a time to see if that is the case. If none are broken, then you only need a spoke key. There are several styles, all pretty cheap, but they aren't all the same size. Look on YouTube for a how video on trueing bike wheels.
If you do have a broken spoke, and it is on the left side, then it's not too hard to replace. Just get the right size spoke and spoke key and you can do it without even removing the wheel. If you have a broken spoke on the right side you will almost certainly have to remove the wheel from the bike. There are several types with corresponding different tools and can be a bit tricky. Look for info on Parktool.com
Jun 21, 2012 | Cycling
I just got Schwinn Adult Trike (one week). Today on a long ride the rear right wheel started making a clunking noise--one clunk with each full rotation. What is that? (this is the first bike I've...
You probably have a dent in your rim or the rim isn't true (true means perfectly straight) either way, take it to a bike shop to get it trued as best as they can manage. It should not cost more than $15 unless you require a new rim. You would only need one if there is a very large, visible dent in the rim.
Jul 17, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Broken spoke in rear wheel. What could have caused it and is a replacement simple?
I ride a Trek 6.9 and have had spokes break for no apparent reason. Most of the time the spoke will break from over tightening on initial installation or just plain fatigue. Replacing the spoke is fairly straight forward. Remove the wheel from the bike and remove the tire. Remove the protective tape on the inside of the wheel to gain access to the spoke nut. After replacing the spoke you must make sure the wheel is true. If you do not have a set up for this, reassemble the wheel with the new spoke and take the assembly to your nearest bike store. They should have the equipment to true up your wheel assembly
May 31, 2011 | Dahon 7 Speed Folding Bike
I have a new trike that may have ome shipping damage (bought at flea market) The rear axel appears to be bent. severe wheel wooble. is there some adjustment in those set screw type bolts in the center of...
The set screws in the center of the axle are there to keep the axle centered in the frame. Only the right wheel is powered which also means only the right wheel brakes when operating the rear brake. This is because the rear wheels must be able to spin independently when turning because the outside wheel will move faster. Unfortunately no one builds differentials at this price.
If you have wheel wobble you need to determine if the axle is bent or the wheel is not true. Prop up the rear of the bike on a stand and remove the problematic wheel. Manually pedal the bike and check the axle as it spins. If the axle is wobbling then it is bent and will need to be replaced. If it spins true then the wheel is the culprit.
The axle is relatively inexpensive and can be ordered through a Schwinn dealer. Any bike shop should be able to true a wheel for around $15-$20.
Sep 23, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Front wheel wobbles
More than likely the wheel is out of true. There are 2 choices,
1 Buy a spoke wrench and attemp to true the wheel. You can do this by spinning the wheel to locate the spot where the wheel goes furthest to one side then tighten the spoke coming from the opposite side. Do this slowly 1/2 turn at a time. Do not over tighten the spoke. It may be necessary to loosen the other side slightly.
Alternate spokes between both sides of wobble.
2 Take bike to a good local bike shop to be tuned and have the wheels trued. Most shops offer a tune up at low cost. A well tuned bike will last a long time.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 06, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
GMC Denali 700C Road Bike Logo
21 people viewed this question
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
