Question about Sony Playstation 3 (PS3) Console
I can play any game online fine, but when it comes to fifa i send my friend an invite he accepts then nothing happens it just comes up this game session is no longer active, or when i do get a game it says you have lost connection to your opponent. any suggestions?
  • 210 Answers
You need to either give your PS3 a static IP address and then put that IP in DMZ in your router, or you need to open up the ports it tells you in the Fifa 09 manual.
To put your PS3 into a DMZ (To be done on the PS3 Console)
Firstly, you will need to assign your PS3 a static internal Ip address. This means that everytime your PS3 connects or "talks" to your router, the router will assign it a different internal IP address. These IP addresses typically run in series. So for example, if your PS3 is the second device communicating with your router, then it will be assigned an ip address of 192.168.1.3. However, if you choose to use your PS3 without the computer being on, the assigned IP address your PS3 has will be 192.168.1.2. As this is different, and obviously will change, it would be stupid setting a DMZ up on one of the above Ip addresses, unless your PS3 was the only device that would ALWAYS connect using that specific IP.
To make sure that your PS3 is always assigned the same internal IP address by your router, you will need to go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 Cross bar menus.
You will be presented with an option which primarily asks whether you are using a Wired or Wireless connection. Obviously, you will choose the option which refers to you. If choosing the Wireless option you will need to input the security details in use on your router *If you are not currently using wireless security, i strongly reccommend you do so ASAP*
Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
This will display a page where customisable IP Addresses are available to be selected.
IP Address - This will need to have the Static IP address in it. Personally, i use 192.168.1.100. I use this because it is extremely unlikely my Router will ever automatically assign this IP Address to a device, as i will never have 99 other devices connected to the same system.
Subnet Mask - Is always set to 255.255.255.0
Default Router - Is the internal IP Address of your router.
To get the exact ip of your router you should go to
Start
Run
cmd [Hit Enter]
Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
Primary DNS - Same IP Address as "Default Router"
Secondary DNS - Same IP Address as "Default Router"
After entering all of these IP Addresses, you will now click "Enter" or hit the "right" button on the D-Pad. This will take you to a screen which says "MTU" at the top. My setup has this as Automatic, solely because i haven't a clue what MTU actually means or does.This won't affect your ability to set up a DMZ.
The next steps are very simple. You do not want to use a proxy server unless you connect to the internet using one, however i can be of no help there, and you should enable UPnP if your router supports it.
To put your PS3 into a DMZ (To be done on the PC)
Now head over to your PC, and load up your internet browser. In the Address Bar, type the IP Address of your router (the one you found using the Command Prompt earlier)
This will take you to your Router Configuration Page.
Every router interface differs from an other, and depending on what router firmware update you last installed, router interfaces can differ, even on the same model routers. This means that you will need to search the router config page yourself. You are looking for any mention of "DMZ" or "DMZ Host"
When you have found this, it will ask you generally to input the IP Address of your DMZ Host, which is just the static IP address you assigned to your PS3 earlier, my example was 192.168.1.100, so we'll stick with that. Then click "apply" or similar.
You should then turn off everything running on your home network. PS3, PC, Router etc. This is solely to make sure that the changes are applied as soon as possible.
This should fix all of the problems as listed earlier in this guide, and probably some other issues
Posted on May 19, 2009
    Problem Solver:
  • 15 Answers
Use the site For the IP-Address Details http://www.ip-details.com/
Posted on Jul 02, 2009
When i try to play online on fifa 11, it freezes and i cant go back. then i have to switch the PS3 off. it keeps happening and i can't play online now
This problem has nothing to do with your PS3!! Its Fifa 11 which is very full of glitches. This freezing problem is a known bug and Fifa or EA doesnt seem to care about it. if you search online you'll see multiple people with similar complaints on EA forums and few or no replies from EA. They havent come up with a fix yet. all you can do is wait for an update (ie. Fifa 12)
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
How do i play online co op in resident evil 5 for ps3? (ie i want to play with me specific friend, how do we join the game together)
o.k. this is an easy one but its set up in a weird way. first go and start a game or chapter select. next you'll select your difficulty. on the next page which is titled "NETWORK" change the co-op settings to "invite only". after u have that set start the game as usual. now on your controller push the ps button to bring up the xmb. go over to the friendslist and choose the friend u want to play with by pressing /_\ (triangle) .. on the top you'll see "invite this player" once thats done your friend should accept and be able to play with you. hope this helps
Apr 01, 2010 | Capcom Resident Evil 5 for PlayStation 3
My ps3 wont connect to my friends
The problem is your internet is not good enough to host or join their game. There is probably some type of connection problem or their game is full. Hope this helps.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Can't play madden 09 online on ps3
Greetings,
from the opening menu choose online and then either play now, or goto lobby. If you goto lobby choose lobby, (for starters pick my skill level) and then you can click on someones name and invite to a game, or if the invite you it will say so on the scrolling info bar at the bottom of the screen, thier name will also have a lightning bolt next to it if they invited you. click on them accept invite and try and win. my ID is dannmidge on the ps3 if you want to add me and we can play.
Aug 22, 2009 | EA Sports Madden NFL 09 for PlayStation 3
I can not connect to my friend when trying to play online. I tried to send him an invite, and he recieves an error. I accept his invite and i get a message downloading game settings and nothing happens. I...
Welcome to the servers at call of duty :)
I've got a ps3 and call of duty 4+5, half the fun of the game is playing with a mate and I've had exactly the same problem as you. It just seems to be about trial and error sometimes, have tried connecting like you for over an hour before and then on other days it just connects wth my mate straight away.
Sometimes it helps to join a game(so you can see and hear other players) then invite your mate, if he/she to reply to your invite is quick sometimes you can get in that way.
The only other bit of advice is to try different times of the day as the load on the servers does change throughout the day, apart from that it really is an issue with activision and for me the playstation network
hope it gets better for you
tim
Jul 08, 2009 | Activision Call of Duty 4 Modern Warfare...
Can not invite friends to play
invitation and accepting is one thing but that doesn't mean they can get in and it's a possibility that they're having a problem getting in which is why you should alway update via internet when it comes to this
Jun 08, 2009 | EA Sports Video Game Consoles & Games
Can play COD 5 online but cant play with friends
u should try to invite ur friend to a (co op) party if he's in ur party then go to multiplayer and invite him again it works with me every time.
Nov 30, 2008 | Sony Playstation 3 (PS3) Console
GAMING ONLINE
Yes you can...
1) Take your WII out of the box.
2)
Connect your WII to the internet. This needs to be through a broadband connection such as DSL or Cable.
3)
A menu will appear.
4)
Find a game for online play.
5)
Some of those that are possible for now (more to be added in the near future) are:
Mario Strikers Charged Football
Endless Ocean
Guitar Hero III: Legends of Rock
NBA Live 08
FIFA 08
Madden NFL 08
Pokemon Battle Revolution
I've listed more games in your premium question.Please go through.Also please don't forget to accept my solution as fixya.
5)
Follow the WII instructions for swapping friend codes.
Thats all and you can play easily..
Please don't forget to accept my solution here and also the premium solution.
Jul 10, 2008 | Nintendo Wii Console
Call of Duty 4 online invite problem
this is a common problem. one of you needs to reset your internet connection... i used to have the same problem. (its not a setting issue)... this should work but if it doesn't, please let me know
please rate this solution
Jun 18, 2008 | Microsoft Xbox 360 Console
Playing and inviting friend online with Playstation 3
Try finding a patch online I do think I had seen something on the ps3 forums.. should be taken care of rather soon its not just you with this issue! but its not everyone!
May 23, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
355 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
