Question about Raymarine St1000 Plus Tiller Pilot
Brown & blue wiring 12 volt which is positive?
    Problem Solver:
  • 9 Answers
Blue should be positive. Is there no way you can trace it back?
Posted on Jan 11, 2014
I HAVE TWO YELLOW WIRED POWER AN WHAT..95 CAMARO REWIRING RADIO
Below is a listing of the radio wires and what they control.
1995 Chevrolet Camaro car radio wiring schematic
Car Radio Battery Constant 12 volt Wire: Orange
Car Radio Accessory Switched 12 volt Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire: Tan
Left Front Speaker Negative Wire: Gray
Right Front Speaker Positive Wire: Light Green
Right Front Speaker Negative Wire: Dark Green
Car Audio Rear Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire: Yellow
Left Rear Speaker Negative Wire: Brown
Right Rear Speaker Positive Wire: Dark Blue
Right Rear Speaker Negative Wire: Light Blue
Jul 08, 2014 | 1995 Chevrolet Camaro
What is the color code for the radio ? we are changing the radio and need the wire codeing for the factory radio
For 2001 Buick Century Car Radio Stereo Audio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Stereo Antenna Trigger: Pink
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope helps (remember to rate this answer).
Dec 30, 2010 | 2001 Buick Century
Replace factory stereo with after market for 98 Dodge Ram 2500
Right Rear Spkr (-) Blue w/ Orange Stripe
Right Front Spkr (-) Blue w/ Red Stripe
Right Rear Spkr (+) Blue w/ White Stripe
Right Front Spkr (+) Purple
+12 Volt Ignition Wire Lite Purple w/ White Stripe
+12 Volt Battery Wire Pink
Left Front Spkr (-) Brown w/ Red Stripe
Left Rear Spkr (-) Brown w/ Blue Stripe
Left Front Spkr (+) Green
Left Rear Spkr (+) Brown w/ Yellow Stripe
ground would have to be connected directly to vehicle's frame
Jun 05, 2010 | Car Audio & Video
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
I need to know,when adding a ampliffier to the factory deck to a 2008,nissan altima.what wire do you connect the remote wire from the amp to?
Here is the diagram but make sure because this car has an amp. installed. To check the right wire you have to use a volt meter and check if you have 12 volts. at this wires (Blk/Pnk or Blk/Grn) as soon you turn the stereo On
2008 Nissan Altima Car Audio Wiring Diagram
Battery Constant 12v+ Wire: Yellow/Red
Accessory Switched 12v+ Wire: Violet/Yellow
Ground Wire: Chassis
Illumination Wire: Red/Blue
Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Black
**Amp Trigger Wire: Black/Pink or Black/Green**
Amplifier Location: Under the Rear Deck
Left Front Speaker Positive Wire (+): White
Left Fron Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Brown
Left Rear Speaker Positive Wire (+): Orange/Black
Left Rear Speaker Negative Wire (-): White/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
Jan 11, 2010 | Car Audio & Video
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
Cant install aftermarket stereo
The Wht/Blue wire is allways 12 volts; The Ylw/Red is switched only when the car key is on accessories.
1994 Isuzu Amigo Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: White/Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Illumination Wire: Blue/White
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 5 1/4′
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Jan 04, 2010 | Car Audio & Video
What do the wiring colours mean?
This is the typical configuration for the wires coming from a car stereo.
Right Rear Spkr (-) = Purple w/ Black Stripe Left Rear Spkr (-) = Green w/ Black Stripe Right Front Spkr (+) = Purple Gray Left Front Spkr (+) = Dark Green White Right Rear Spkr (+) = Blue w/ Orange Stripe Purple Left Rear Spkr (+) = Brown w/ Blue Stripe Green Power Antenna/Amp = Blue +12 Volt Battery Wire = Yellow +12 Volt Ignition Wire = Red Right Front Spkr (-) = Gray w/ Black Stripe Left Front Spkr (-) = White w/ Black Stripe
Jul 07, 2009 | Car Audio & Video
I need help wiring a pioneer to a 1992 cavalier cuz the wires dont mach up
the cavalier wiring-top row is orange 12 volts regardless of the key switch position,yellow 12 volts when the key is on/or accessory, pink is for power antenna or factory amp turn on, grey is for lights dimmer control, black ground,green right front speaker +,light green right front speaker -,grey left front speaker +,tan left front speaker-, bottom row is brown left rear speaker +,yellow left rear speaker-,blue right rear speaker+,light blue right rear speaker- be carefull because you have 2 yellow wires and 2 grey wires if you follow the rows like I explaned you will be fine-If you need the wiring for the pioneer radio E-Mail me at merle840@aol.com
Apr 04, 2008 | Pioneer DEH-1900MP CD Player
Raymarine St1000 Plus Tiller Pilot Logo
140 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
