Question about Tablets & eReaders
How to reset android traveltek tablet
It comes on and then goes trough the booting up process to the android screen and then just goes blank
5 Suggested Answers
SOURCE: buenas noches, tengo problema con
A mi tambien me salio, no me dejaba entrar a ninguna aplicacion, no lo podia quitar. Tuve que recuperar el sistema operativo para regresar al inicio de fabrica aqui te dice como hacerlo es muy sencillo http://latin.aoc.com/support/troubleshooting.
Te borra las aplicaciones que tengas instaladas pero lo que tienes guardado en tu memoria se mantiene.
No se como evitarlo para, si alguien puede decirme, tks.
Posted on Aug 04, 2011
SOURCE: The tablet turns on but seems frozen and shows the android screen and nothing else. Tried to reset it but it does the same thing
so wat do i do
Posted on Dec 28, 2011
jrolph621
  • 7 Answers
SOURCE: how do i unfreeze my android tablet after factory reset
let it sit at room temperature until it thaws out :-D
Posted on May 31, 2012
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
How do I unlock my tablet
If it's android then you can reset it but you will lose all the apps you installed along with any saved passwords.
power off the tablet by holding down power until screen goes blank.
hold both the power button and the volume up button for at least ten seconds.it should boot to android logo...then a robot with red exclamation.leave it alone until the option to reset screen appears.
follow onscreen instructions to reset.
Jan 26, 2015 | Tablets & eReaders
Trying to hard reset my Traveltek tablet.
There is a reset button inside a small hole on the tablet, that can be pressed with a paperclip. Please specify which model you have.
May 16, 2014 | Tablets & eReaders
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Line with bubbles on blank screen
holding the power button down until the unit goes off should do the trick.
Feb 12, 2014 | Toshiba AT200-101 ANDROID TABLET
TRAVELTEK tablet manual
How do i factory reset my android traveltek tablet
Jan 21, 2014 | Tablets & eReaders
Tablets & eReaders Logo
1,009 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
