Question about Cycling
Falcon gear shifter diagram - Cycling
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Where do I buy a
Google.
For example:
http://www.bikepartsusa.com/bikeparts/item/01-129762/shifter/Pyramid--Shifter-56-Speed-Falcon-Right-Only&category=shifter
Posted on May 01, 2011
How To know if Yo gearbox is faulty on a Ford falcon futura 4,0 automatic engine
go under the car to side of transmission where linkage hooks to shift levers have someone shift the gears look to see if shifters on trans. are moving and the linkage is working fine.
Apr 05, 2017 | Ford Falcon Cars & Trucks
Ford Falcon 1984 Manual- Tried to select Reverse gear lots of grinding - then gear stick went 'limp' could not get into any gear after that
sounds like your clutch is bad and you ripped all the gears out . only a transmission mechanic can help you now
Jan 30, 2017 | Ford Cars & Trucks
Gear shifter will not come out of park
Probably a problem with shifter interlock . This interlocker will not let gear shifter move without your foot on the brake pedal . , brake switch sends a voltage signal to usually A BCM - body control module , which controls a solenoid which unlocks the shifter interlocker . Find a wiring diagram at http://bbbind.com/free_tsb.html to test the electrical part of the system . http://www.autoshop101.com/forms/h18.pdf
Oct 07, 2016 | Cars & Trucks
I have a falcon 150 fully automatic with reverse shifter that's stuck in gear and won't crank or move if you push it
Wild guess you have something like an interlock that cars have.
The key must be working properly, any security codes. Electrical problems.
Apr 01, 2015 | Motorcycles
The lever on the right shifter is broken. I am just trying to find a replacement shifter. Do I need to replace with the same brand, or any 15-speed shifter?
You need to use the same one or one that is compatible with the gears in the back. I.e. a Shimano shifter will move your derailer a slightly different distance than a SRAM or campi shifter. You should talk to you local bike shop for more advice
Jul 12, 2011 | Mountain Falcon Ml-10 Bicycle...
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
Need a diagram or a5 speed gear shifter for a
The only place I know to get what you are looking for is faxonautoliterature. They deal in old dealer service manuals and they have one for your car. This is the original Chrysler service manual. I have used then before and found their service to be excellent. Hope this helps.
Nov 02, 2009 | 1994 Plymouth Laser
Need a diagram to replace steering gear in ea
Sir,
Try these links....
Link 1
Link 2
Link 3
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 07, 2009 | Ford E-Series Cars & Trucks
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
