Question about ZVOX ZBase 580
No power to the unit..although outlet is working. The unit doesn't seem to be able to be turned on. Unit is 2 months old.
GE microwave over the range, model #jvm1740sm1ss has no power.it's only two year old.what could be the cause?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson microwave 1100 watt microwave keeps running even when timer stops bought about 7 months ago
Regards.
Oct 18, 2011 | Emerson MW8168B Microwave Oven
Our 4 month old Frigidaire FRA256ST2 stopped working today.We had an eletricain check the plug and the unit is getting power.When you plug it in and press the reset,it beeps,LCD flashes but doesn't...
A dirty or clogged air intake filter will prevent the unit from turning ON, as a safety feature. If that isn't of doesn't solve the problem. Contact Frigidaire 1-800-944-9044. As you unit is still under 100% warranty at this point. They will repair it or replace it at their option. Don't do anything to the unit, that could possibly void the warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Frigidaire FRA256ST2 WallWindow Air...
Philips Home Theater System (HTS3371D) will not turn on. Approximately 2 years old, never had a problem. I woke up today and the red indicator light is off and the system is completely unresponsive. It...
Have you contact Philips customer service and described your problem? I would suggest you start with them. If your outlet is supplying voltage and the unit is not turning on chances are there is a fuse inside the unit that is blown. The unit would not be hot because a small amount current is no longer flowing into the unit which is indicated by the led light no longer being lit.
Aug 10, 2011 | Philips HTS3371D Theater System
Everstar mpm2-10cr-bb6 will not reset on power cord. light on reset doesn't light. seems like no power is getting to the unit.
Check the outlet that the unit is plugged into, to be sure that it is in fact, working. The circuit breaker in your home's circuit breaker panel for that outlet, may have tripped. Also, the outlet may have interior damage or a loose wire connection. If the unit seems not to be getting power, one of the above is the problem. Try plugging the unit into another outlet in a different room.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Danby DPAC8020 Air Conditioner
My 305 unit will not turn on. It has been sitting on the charger for 3 days..Is there a reset option? It is only 2 months old, but is a refurbished unit. It was working fine the last time it was used.
try pressing the mode and power buttons together although you may lose your data, if this does not work leave it off the charger for a few hours and then try to start it,, this happened to my olde 305 and after leaving it overnight it started again....they are sometimes tricky
Sep 12, 2009 | Garmin Edge 305 HRM kit
The Wii console is not powering up at all.
Hi there, this is a power board failure. It seems to be a manufacturing error considering the fact that, this Wii is only 2 months old. i would excercise the warranty if possible and return for exchange. this is a defective unit.
Feb 18, 2009 | Nintendo Wii Console
Dead Monitor
the monitor is dead
Jul 26, 2008 | Compaq V700 17" CRT Monitor
ZVOX ZBase 580 Logo
271 people viewed this question
Top ZVOX Televison & Video Experts
Tom Chichester
Are you a ZVOX Televison and Video Expert? Answer questions, earn points and help others
