Question about Kenmore Dishwashers
Pods not dissolving in kenmore dishwasher
My dishwasher door is not opening and the detergent pods are not dissolving, how do you fix that?
onthejob5130
  • 640 Answers
SOURCE: detergent falls out and doesn't melt
check water temperture its not hot enough..onthejob
Posted on Feb 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
  • 37 Answers
SOURCE: Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Posted on Jan 22, 2010
SOURCE: dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
Posted on Aug 06, 2010
Our dishwasher is not dissolving the soap. Has anyone else had this issue and does anyone know how to fix this problem?
Try using a liquid dishwasher detergent.
Also, if you are using dry detergent (that is not pre-measured in pods, etc.), you may be overfilling the detergent dispenser. When the dry detergent gets wet, it swells and causes the detergent dispenser door to stick.
Apr 13, 2016 | Frigidaire Dishwashers
The door that holds the detergent does not open, so the detergent pods do not dissolve
A last option is to throw in the detergent pod manually. I have done this in the past and works well. Cant hurt to try.
Feb 22, 2016 | Dishwashers
Model 665.17534291. Why isn't it cleaning dishes?
Is the water pressure on maximum? Is the drain hose aiming 'UP' before running into the drain?
Jul 06, 2015 | Kenmore Dishwashers
Kenmore dishwasher we use new finish detergent and the little soap pouches do not dissolve.
DOES THE SOAP DISPENSER DOOR OPEN, IF SO THEN EITHER THE WATER FROM SPRAY ARMS NOT REACHING THE DISPENSER, POUCHES IMPERVIOUS TO WATER OR REQUIRE HOT WATER AND WATER IS NOT HOT ENOUGH. CHECK THAT THE SPRAY ARMS ARE NOT CLOGGED WITH DEBRIS. ALSO COULD BE SOME UTENSIL KEEPING THE SPRAY ARMS FROM ROTATING.
Mar 09, 2010 | Kenmore Dishwashers
Gel paks don't dissolve
Before you start the machine make sure the water is hot enough going into the dishwasher. Sounds like the water temp is not hot enough to melt paks or dispenser is not opening.
Feb 24, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Detergent does not dissolve.
Make sure that the water supply going to the dishwasher is HOT. Detergent will not disolve in cold water.
Sep 15, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
Aug 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Jul 31, 2009 | Electrolux Dishwashers
Hi!
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
