Question about Bulova Watch
Set alarm on le coultre watch 1960
How to set the alarm on le coultre watch 1960
What what what????
Posted on May 19, 2009
I have Bulova and found on the case M0 or MO, does this mean the year 1960?
Yes, Bulova used M0 to indicate the year 1960, but the marking on the case may not necessarily match the movement. It is not uncommon to find a movement that was produced one year earlier or one year later in a case made for the model. So, although the case of your watch was produced in 1960, the movement may be from 1959 to 1961.
Apr 03, 2015 | Bulova Watch
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    I can't set my watch. The hands will not move to set the analog time; all digital information appears to work fine. The alarm works (it does ring but I just can't seem to set the analog watch time. The...
    I would consider taking the watch to a professional jeweler, it probably needs a good cleaning and possibly a part replacement, given the fact the watch is 22 years old.
    Mar 13, 2011 | Le Chateau Watches
    I have a le coultre clock that will only run for about 6 hours. it is sitting level,but the pendulum just stops.
    Hi, Firstly a Le Coultre clock is a fine thing and most be treated with care and attention. If the clock is sitting level (use a spirit level) then there is obviously a fault, which to me sounds like it could be in the hairspring. As the clock is obviously of age, it is very possible that all that has happened is that dust and stuff has gathered around the hairspring, causing it to not wind as tight as it really needs too. I would suggest sellotaping a ladies tight over the end of a hoover attachment and giving the movement a good old hoover. The tights will catch anything that comes off, so you can inspect it. The movements will need oiling too, once oiled you will see a difference. Hope this helps. Tom from Luxuysauce dot com
    Apr 20, 2010 | Watches
    Sector 250 Chronograph Alarm
    the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
    pull the middle dial out to put it in alarm mode.
    To set alarm:
    -pull the center knob out.
    -with it out you can now use the bottom (right) knob to set the alarm.
    -pull the bottom right knob out one notch
    -turn the knob clockwise or counter clockwise to set the alarm time
    -push the knob back in (all the way)
    the alarm is now set
    if the center (right) knob is pulled out the alarm is ON
    if the center (right) knob is pushed in the alarm is OFF
    I have owned this watch for about 10 years now and love it.
    the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
    repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
    enjoy the watch!
    Dec 11, 2008 | Sector 2653940025 Wrist Watch
    How to adjust alarms
    moz-screenshot.jpgSetting the alarm:
    1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
    2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
    3. Push the crown to normal possition
    4. Pull the crown to the 1st "click".
    5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
    6. Push back the crown in to normal position.
    At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
    Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
    Watch isn't recognised by computer
    Hi Hoffman518,
    To set the alarm on your Timex Ironman, please follow the steps below.
    1. Begin by pressing the "mode" button until the alarm screen appears.
    2. Press the "set" button and use the "advance" button to set the hour for your alarm.
    3. Repeat the same procedure to set minutes and seconds for your alarm.
    4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
    5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
    Hope it helps.
    Thank you for using FixYa.
    Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
    Bulova Watch Logo
    56 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
