Question about Coffee Makers & Espresso Machines
Espresso machine verismo 801
Just bought my machine . fill it with water. put in pod. makes noise but nothing happens. wont **** the water into the machine
SOURCE: Hot water won't flow into machine
We stumbled across a solution to this same problem by filling the reservoir about half full, putting it in place, and reaching down to the bottom (small hands required) to pull the plunger open. The machine was running at the time, set to run water through the filter holder, which had no grounds in it. It may not be necessary to have the machine on. Good luck, Gene
Posted on Dec 26, 2007
  • 54 Answers
SOURCE: Espresso maker doesn't work properly
It is clear that there is a problem with water supply. Check if pump works, if it does, there is blockage in water supply to pump. Check and clean.
Posted on Jul 11, 2009
SOURCE: verismo 801
milk gets sucked into the boiler when the boiler rapidly cools and creates a vacume while your steaming milk. this can be caused by water inlet problem involing the level probe inlet valve or level board. there is also an anti syphon valve that is built into the overpressure relief valve that could be malfunctioning.
Posted on Sep 11, 2009
  • 3 Answers
SOURCE: I need to buy parts for a verismo 801
I have parts for sale. Contact me at lattefarms@yahoo.com
Posted on Sep 22, 2009
SOURCE: water leaking in espresso machine
I have a Krups 2010 and it leaked from day one I used it for about a month before I decided to fix it myself instead of paying for shipping it to them. After opening the back (yes the warranty is broken) I took some photos and here is what I found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo). This machine still makes one of the best espressos I have tasted and now it is one of the easiest to clean.
Posted on Jan 07, 2010
The red light comes on and then goes green. Filled with water and pod in but nothing happens. Completely silent.
one step at a time do you get water with out putting the capsule
what is it doing is there any sound coming from the pump do you have any flashing red light? need more info
Jan 11, 2016 | Krups Dolce Gusto KP 2100 Espresso Machine
The lever wont close all the way after I insert pod?
You can move the handle slowly up and down until the coffee pod drops down. Be sure the used pod holder underneath is empty.
Mar 07, 2015 | Starbucks Single Serve Brewer, Verismo 580
Verismo pods are splitting
I would definitely return the pods. They are probably an inferior batch and they would probably exchange them.
Apr 01, 2014 | Starbucks Single Serve Brewer, Verismo 580
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Starbucks verisimo clogged and the spout is shooting off
If your machine is clogging, try running the water through the machine, Press the button that [looks like a little shower icon on the top left] first. May need to do it twice. Do that each time before you put a coffee pod in the Verisimo.
Feb 28, 2014 | Starbucks Single Serve Brewer, Verismo 580
Verismo 801
Sounds like a problem with the pods. Check they are manufacture recommended. When on espresso the pressure will be higher so a
"weak" pod could cause this. Unless the machine is producing too high a pressure. Check also there are no projections that could rip the pod when you close the holder.
Jan 28, 2014 | Coffee Makers & Espresso Machines
GW612 wont fill ith water
Try to swap the solenoids to see if that will fix the problem.
If it fixes the problem replace the faulty Solenoid.
May 30, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fill tank with water and put plastic coffee pod in place. Press the power button and cup size and nothing happens except a smelly substance is injected into the water tank.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 13, 2011 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
