Question about Epson Stylus Photo R220 InkJet Printer
R200 Stopped printing black only
I have the Epson R200 and just the other day it stopped printing black.. The color prints fine, but nothing black will print.. I have changed the cartridges out 3 times with new ones AND I have done everything under head cleaning that the system allowed me to do and it will still not work.. I do not have the money to send this to a printer repair person that will probably just take my money to tell me they cant fix it.. This printer is less than a year old.. what can I do?? Please help.
  • Anonymous Nov 02, 2007
    R200 will not print out black ink. Other colours are fuzzie. Changed complete set of ink cartridges twice.
  • 749 Answers
"This printer is less than a year old." Well it is under warranty... have it checked from its vendor, I am sure that it is free. Unless they have a 6-month warranty on you.
Posted on Oct 31, 2007
  • Rommel Balcita Nov 16, 2007
    Sometimes it is not the cartridge is the problem... it is the so-called print-head... can't change that only their service center can, or the manufacturer can. It happens when you are not using the printer too often, since the printer is built to print at least everyday... do you?
I CANNOT PRINT BLACK ON MY EPSON STYLUS PHOTO R200. All other colors print. I have replaced all the cartridges. This is my forth attempt at trying to contact you people. CAN YOU HELP ME?
this issue may have several causes:
1. make sure that you've removed the yellow ribbon from the top of the cartridge before installing it. it is there to keep the ink fresh before it's installed and has to be removed to enable the ink to flow into the print head. (not all epson cartridges have this ribbon though)
2. check all the settings in the printer driver or simply remove the current driver completely and reinstall the latest driver you can find on the epson site.
3. the black print head may be clogged. in this case, performing cleanings will help, possibly several cleanings are necessary
4. there may be a faulty connection between the printer's mainboard and the print head.
5.there may be an electronical problem with either the print head or the mainboard.
in the last two options it's better to let a professional technician look at it.
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
I have an Epson Stylus Photo R200 that will not print
i am not sure where you are leading, but I assume you want to print with the black without changing the colors. No, you are not able to do that. If the colors require replacement, you have to change them before you can continue to print.
thanks
Aug 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Gradually stopped printing, first colors, then black. New cartridges no help.
check all the catridge installed ok after finding the gatridge ok if the problem not solved , then uninstall the printer driver and restart after restarting the machine then again reinstall the printer driver properly
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Epson photo r200
Sadly, if only one cartridge is empty, an Epson printer won't print. But, you can bypass that by using a chip re-setter. They have them in refill stores. By using a chip re-setter, you assign a new serial number to your cartridge, thus "fooling" the printer you have put a new cartridge in. Then, you don't need to refill all the cartridges.
Sep 09, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 - print with black ink only
Nope.....
Epson will not print unless all carts have ink in them to some degree. If the light is on for any reason, printing will be halted.
For future reference, once the color carts have been replaced, you can set the printing defaults to print in either gray scale or BW only. Keep in mind that Epson printers tend to mess up if you don't use the ink at least once a week.
Aug 01, 2008 | Epson Stylus Photo R200 InkJet Printer
No black
Hi good day try to head cleaning twice and test print nozzle if colors complete try again printing pictures.
May 01, 2008 | Epson Stylus Photo R320 InkJet Printer
Black ink
I had a similar problem with the r320 epson
I found that it had blocked.
this works well to clear the head
1 switch on the printer with the cover open
2 as the cartridge head moves away from its docked position pull the mains plug.
3it is then possible to slide the head to the left .
4 there is a square of flet on the right the head would normally be over, add a squirt of mr muscle bathroom cleaner on the pad ( main off)
5plug the printer back in and the head will return the the docked position.
6 leave for and hour or 6 then try to print
Dec 03, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
290 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
