Question about Panasonic KX-T7730 Corded Phone
Retrieve last 10 dial out number
Will the handset save the last 10 dial out number ? if yes, how to retrieve it?
    Problem Solver:
  • 19 Answers
Same as the other one
It will mainly depend on the setup but usually the last 10. TO access the last 10 select the soft key menu button, down arrow on silver dial to outgoing call log. Let me know if that helps.
Posted on May 22, 2009
Where can I find operating instructions for a Jazz 4400 telephone. I want to change the speed dialing to 10 digit but can't find the original instructions.
Jazz 4400- Programming an Autodial key: 1) Lift handset wait for dial tone 2) Press SAVE key 3) Dial the number you wish to save 4) Press SAVE key again 5) Press the Autodial key that you want to save number to. // Notes: The number can be up to 16 digits. If you need to add a pause (for PBX system) press REDIAL key. //
Jazz 4400 has 10 Autodial keys each can store 2 numbers for a total of 20 saved numbers. Press SHIFT key before Autodial key to access second number. Their is a HOTLINE key to store one frequent or emergency number programmed same as Autodial.
Aug 20, 2014 | Nortel Jazz Plus 4400 Speakerphone -...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
How to set speed dial on panasonic kx-t7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Apr 12, 2010 | Panasonic KX-T7730 Corded Phone
Hy is my blackberry pearl not showing who my message is from
Cause:
  • Number is not saved in the address book
  • Issue with the setting in the handset
  • Software issue
Resolution:
  • If the name is not saved then saved the name in the handset
  • In the handset go to Call logs -> Menu -> Option -> Smart Dialing -> Country Code is +91 and Option ->Security Option -> General Settings -> Include Address Book -> Yes
  • If the above two option is done then re-install the software.
Jun 18, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Retrieve the latest 10 dial out number
May 19, 2009 | Panasonic KX-T7730 Corded Phone
How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
Apr 21, 2009 | GE 29267 Corded Phone
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Jul 12, 2007 | Conair SW324WCS Corded Phone
Problem when dialing phone
Yes, I have had nothing but trouble with my V-Tech ia5823.
Slow to dial, dropping out going calls and now the base light is flashing at a rapid pace and will not charge the handset.
I want to return it to Wal-Mart but have misplaced the recepit.
I will never buy another V-Tech..Uniden is the way to go!
Jun 02, 2007 | Vtech ia5823 Cordless Phone
Panasonic KX-T7730 Corded Phone Logo
248 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
