Question about APC Matrix-UPS 5000 UPS System
APC Matrix 5000 Electronics unit
Dear ALL,
My APC Matrix 5000 doesn`t work, the power unit runs but electronic unit with the display does not switch on.
Can anyone help me to check and fix the problem ?
Thanks in advance,
How can i fix this i am having same problem. When i plug it in the mains wall socket the fan turns on and a relay click sound is heard. But there is nothing on the display region. I have changed the lcd aswell but invain. Please help
Posted on Jan 04, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Try to check the screw behind your IU try to tighten it, the purpose of that big screw is to push the switch of your EU to make it on. Btw if you could explain the problem further is much better. If the power is on and and there is no display on the LCD and if there is a power outage and your UPS still giving power to the load, it might be the LCD problem or the display just go on standby.
Posted on Feb 20, 2013
    New Friend:
  • 37 Answers
Where are u from ? here my email brokenbutte@yahoo.com.sg
Posted on Jun 05, 2009
How to monitor Matrix 5000 UPS via email?
Try using use the agent and server of the Powerchute plus and the console of powerchute business edition run from another PC.
You may need version 9 or later of PBE.
Jul 29, 2014 | APC Matrix-UPS 5000 UPS System
Hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
Display reads sonar timed out
check the battery voltage as low voltage can cause the unit to display errors and prevent the sonar from starting up. This unit is more sensitive to low voltage than many other electronics. If charging the battery or replacing it with a known good battery doesn't work then contact garmin for a replacement of your fishfinder.
Nov 18, 2010 | Garmin Fishfinder 400c With Dual Beam...
Had a power break, expected power to come back so
t_sleeswijkv, Your unit may need factory servicing. Could have been hit with a large overvoltage transient spike that may have damaged unit electronics. Give a call to APC or visit their website for more advice on best way to proceed. I hope it never happens to my APC 1250. I did a DIY replacement of 2 batteries in mine back in 2007 because one went bad. If your unit not covered by warranty open it and take pics of what stuff got burned-up or fried. let us know what you find. 12fixlouie on fixya
Mar 17, 2010 | APC Back-UPS Pro 1100 (BP1100) UPS System
I need to know what the modular cable is that goes between the main unit and the batteries on a Matrix 5000. Is it simply a cross-over mini-RJ11 (handset connector) cable?
ccowl, APC has a great website. Have you tried it yet? The knowledge base they have on their products is huge. The cable you are speaking of may just be for monitoring battery voltage status, but that is only a guess. The interconnect cable could be a proprietary APC cable and only APC knows how it is wired "end to end" !!! 12fixlouie
Mar 16, 2010 | APC Matrix-UPS 5000 UPS System
Battery Charging Failed on APC Matrix 5KVA
you will need to replace the unit. the charging circut has failed
Dec 27, 2009 | APC Matrix-UPS 5000 UPS System
Relay switching sound
Have you change the battery? Note: Matrix UPS need to be calibrate after changing batteries or reset the Smartcell communication board. to make sure that the UPS would detect that you already replace it with the new battery
Jul 30, 2009 | APC Matrix-UPS 5000 UPS System
Could you tell me how many batteries a matrix UPS 5000 has in it as well as an APC Smart UPS Smart cell
A UPS 500 uses two smartcell batteries. As for the APC Smart UPS, there are different models, but most UPS's will generally use two batteries.
Jun 23, 2009 | APC Matrix-UPS 5000 UPS System
No battery communition display on lcd
Make sure that the battery communication cable is connected the the battery output communication of your smartcell. If Im not wrong maybe you connect the communication cable on the input of the smartcell communication board.
Thanks and Good luck
Apr 23, 2009 | APC Matrix-UPS 5000 UPS System
No battery communications
You will get that message when the communications cable is not hooked up. It looks like a phone line and daisy chains from one battery to another and ends at the Matrix Control unit. If you have those installed and it still says no communication the system need service.
If you have a volt meter you can check the voltage from each battery at the plug. It should be 48 volts or more, usually on a fresh battery pack it will read 54.0+ volts.
Hope this helps,
Dean
Dec 09, 2008 | APC Matrix-UPS 5000 UPS System
APC Matrix-UPS 5000 UPS System Logo
655 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
