Pentus tv colour problem
What should my colour brightness contrast hue and sharpness be set to because my tv is green
VOTIT
  • 2071 Answers
SOURCE: Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Posted on Sep 21, 2008
  • 191 Answers
SOURCE: Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Posted on Nov 10, 2008
Highdefjeff
  • 124 Answers
SOURCE: need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
  • 1779 Answers
SOURCE: Dark screen!!! Bratz 15"LCD1510DB TV-DVD COMBO
That's your main board, they can cost as much as $350.00 some a little less.
Posted on May 03, 2009
1joester2
  • 74 Answers
SOURCE: Cannot navigate Picture Mode (Colour) menu.
After some digging, I may have found something.
With no menus onscreen, press the menu button. Then press it again. According to a post I saw on another forum, that allowed the user to enter the tuning menus.
First press gets you "Overview" and the second opens the tuning menus.
Good luck, and repost the results.
Posted on Jan 09, 2010
Testimonial: "I managed to get the menus working and the colours are set up properly. "
I have a sceptreflat screen hdtv that display a red picture Always
go into settings and check your hue settings.
This setting controls your color mix ratio
of primary colors red, blue and yellow.
Apr 22, 2017 | Televison & Video
Devant tv tech.model no.32DL410 power on but no display on the screen can you help me.???
Try goong to menu and check if brightness, color, sharpness, hue, contrast is set to 0. I have the same model, whenever I use USB in Source, those settings in menu automatically change. If thats the case, go ahead and change brightness to 50, contrast to 50, color to 50, sharpness to 2, hue to 50
Apr 04, 2017 | Televison & Video
What are perfect settings for colour on my Toshiba 22KV500B?
It will depend upon individual viewing taste. Yet, contrast 65%; Brightness 50 to 60% and color 30 to 45% will give a satisfactory picture. https://electronicshelponline.blogspot.com/
Jun 30, 2016 | Toshiba Televison & Video
Plano tv samsung
Adjust the brightness until it starts making the black in the picture slightly milks and back it off slightly
Adjust the contrast so that the whitest whites show detail, too much contrast and they disappear
Adjust colour to suit, start with it half way, look at flesh tones on a news reader as a guide and adjust sharpness so you can see detail but not so that there are false or visible edges around things
May 16, 2014 | Televison & Video
What is the proper calibration settings for a panasonic tc-p50s2n. I have used it for over a 100 hours
Do you have access to a test pattern or color bar ? .If you have a THX certified DVD ( some Walt Disney movies ) it will have calibration setup guide in the DVD menu.Or else you have to buy a calibration DVD if you are serious about your TV setup.
First you have to set the contrast and brightness using the Grey-scale pattern. Seven set of vertical bars slowly progressing from white to black. If set right you should be able to make out all the seven bars with out each merging ( or overlapping ) into the other. You will be able to see the line of demarcation between each vertical bars. Then set the color to taste.
If you do not want to purchase the above mentioned DVD disc a close setup figure for your Panasonic TV would be
Picture Mode = Standard ( Normal )
Picture ( Contrast ) ---- 50
Brightness ---------------- 50
Color ------------------------ 33
Sharpness ---------------- 50
Hue ------------------------- In the middle
This setting should give you a decent picture quality assuming your TV is new.
Apr 12, 2011 | Panasonic Televison & Video
Making my HD tv look the best it can
If you have the halo 3 bonus disk use the THX optimiser on it, if not then the setting I use are:
Viewing Mode: Dynamic
Contrast: 60
Brightness: 50
Colour: 50
Sharpness: 50
Tint: Middle (need the lenses to set it properly)
Colour balance: Cool
Colour Management: On
P-NR: Off
I got both setup through HDMI atm.
Jan 06, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
FOGGY-HAZY PICTURE
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Nov 29, 2008 | Televison & Video
Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Oct 11, 2008 | Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
