Question about Breville BTM800 One-touch Tea Maker
Basket light keeps on blinking, reset and does not heat up water
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
My Gaggia Brera has all four warning lights blinking simultaneously. And won't make any coffee. Ideas?
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Oct 13, 2014 | Gaggia Brera Coffee Maker
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Clean instructions
First, let me clarify what the red light indicates.
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool quite porter the led light blinks 7 times then keeps repeating
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Feb 13, 2011 | Whirlpool Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwasher will not start.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Breville BTM800 One-touch Tea Maker Logo
197 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
