Question about Homelite Garden
How to take out the bulb of the homelite chainsaw 200 classic
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
  • 4088 Answers
SOURCE: Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Posted on Jul 14, 2010
  • 4088 Answers
SOURCE: how to remove snap in primer bulb on homelite
Use a set of pliers to pinch the two 'ears' together so that the bulb assembly can be removed. Try to install the new one in the same relation as the old one so that the two fuel lines don't become reversed. Good luck!
Posted on Nov 13, 2010
  • 1949 Answers
SOURCE: My Homelite Ranger Gas Chainsaw
go buy kit and follow there instion..... each is alittle diff.......
Posted on Mar 01, 2011
Manual for homelite classic 200 chainsaw
gpo google and type in --- workshop manual for homelite chain saw.--- down load any pdf version that suits the 200 series
Nov 27, 2016 | Homelite Garden
Is the primer bulb replacable on 200 classic chainsaw.or do I have to buy a new gas cap.
Hi Shirley:
My apologies if I'm incorrect, but I've never seen a chainsaw that had the primer bulb connected to the gas cap.
So,,,,,
I'm hoping you're asking two questions at the same time.
1) Primer bulbs are replaceable but it's extremely rare that it is necessary
2) Gas caps are replaceable but only needs to be done if they are broken.
If you reply as a comment on this post I'll be able to respond to you.
Cheers.
Oct 14, 2015 | Homelite Garden
Homelite chainsaw gas line diagram witch one goes where have the primer bulb
Take the primer bulb off.Look on the back side of it.Most will say tank and carb.If not try putting them on if the bulb doesen't get gas in it.Change them around.
Feb 27, 2011 | Homelite ZR10926 16" Chain Saw
My chainsaw (Homelite UT10514) will not prime fuel. I have changed the primer bulb and checked the fuel lines for damage, they seem to be in good shape.
You need to make sure the lines are connected properly to the bulb. Also, if the carburetor diaphragms are not working properly the carburetor will not prime.
Feb 12, 2011 | Homelite Garden
How to remove snap in primer bulb on homelite chainsaw
Nov 13, 2010 | Homelite ZR10926 16" Chain Saw
Idle speed for hoelite classic 200 ut 10791c chainsaw?
Idle speed is not usually set to some specific value, but is set to stop chain movement at idle, but allow the engine to keep running. Hope this helps!
Apr 10, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Garden Logo
20 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
