Question about Tefal T-FAL Avante Stainless Steel Electric Kettle Electric Kettle
On/off switch not working
When I switch it on it doesn't work
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
High speed doesn,t work on heater switch.
Pull the heater control panel out of the dash and inspect the blower speed control switch, look for signs of a burnt connector to the switch, it will be discolored looking, if this is the case replace the switch and install a repair connector
Jul 19, 2012 | Cars & Trucks
Drivers not working, doesn't switch on n doesn't
Um, could you elaborate a little using full words and descriptions? Thanks
Apr 07, 2012 | Computers & Internet
1996 buick skylark fan operatiion - How to test it?
Take out the temperture sensor switch and put it into very hot water to see if it works. Plug the hole with something to stop losing water. If the fan doesn't work put some voltage on the motor and try that. If that doesn't work it is the fan motor. If it does then it is a faulty switch.
Oct 26, 2011 | 1996 Buick Skylark
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
The receiver doesn´t work. When i switch on,
the solution: Fount of energy broken and 50€ less in the pocket...lolo
Aug 14, 2009 | Philips E-Box FTR9965 DTV Receiver
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
Kitchen Appliances - Others Logo
27 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
