Question about Arris dct3416/2305 dual tuner dvr / hdtv 160gb
How do you exit the n dl mode of the motorola dct3416 dvr
I have a motorolla dct3416 I dual tuner/dvr box. I received from a friend and wanted to set it up with my dish network cable. However in going into the DVR authorization mode (unplug power cord, pressing power and menu buttons while re plugging the power cord then using the the arrow keys to activate the n dl mode). However the unit seems to be stuck in this mode, and cannot access the firmware from my dish network provider. can anyone help me to exit this mode of the dvr?
How do I reset the universal remote after a long power cut
Find the code and try to reprogram it or have the remote tested to see if it is sending a signal or not---most shops can and will check it for free--a digital camera in a dark room will react (most of them) when remote is pointed at it on the camera display with a flash of light.
Oct 30, 2012 | Arris dct3416/2305 dual tuner dvr / hdtv...
I HAVE A MOTOROLA DCT3416 i THAT HAS BEEN UPDATED WITH ROVI PASSPORT 3.5 AND WILL NO LONGER POPULATE THE GUIDE, CHANGE CHANNELS WITH THE CHANNEL UP/DOWN BUTTONS OR FUNCTION AS A DVR, HOWEVER I CAN DIRECTLY...
WHY ARE YOU SCREAMING?
Nope, not the hard drive. you wouldn't be able to pause at all. Its your remote...
try simple things like checking to see if your in the right mode. (what lights up on your remote when you push buttons?)
IMO if you swap the box you will have the same problem. try a different remote... maybe one from another room.
good luck
Apr 10, 2011 | Motorola Televison & Video
Our Dvr will only record on the channel we are watching. I cannot watch one show and record another? It says I have to be watching the channel I want to record?
for the dual tuner, if you are unsure what this is... please look at the back of the satellite box and see if you have 2 sat in cables. if you do, then you need to reprogram your satellite. if you do not have 2 sat in cables then you would need to contact dtv to get this installed.
Mar 29, 2009 | Directv (R10) DTV Receiver / 70-Hours...
How use Tivo on Motorola DCT6412 III?
this works to record progam you watching
1. press menu key
2. highlight DVR button by using either < or > key then press OK button
3. answer prompts
Do this to set up a recording in advance or a series recording
1. Hit the guide button
2. scroll thru channels until you find program you want to record
3. scrool over to red dot press OK button
4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
Hope this Helps.
Mar 19, 2009 | Motorola Televison & Video
Motorola DVR
Try unplugging the unit for at least one minute and then plug it back in . The unit should reset itself . I will take 20-30 minutes for the guide to repopulate.
Nov 29, 2008 | Arris DCT6200 DTV Receiver
Samsung TV Mode not supported message
check to see if the output is set to 480i. HDMI does not support 480i - http://samsungplasmatvfaq.com/index.php/Display_settings
Oct 08, 2007 | Samsung LN-S2651D 26 in. LCD Television
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
Arris dct3416/2305 dual tuner dvr / hdtv 160gb Logo
52 people viewed this question
Top Arris Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Arris Audio Player and Recorder Expert? Answer questions, earn points and help others
