Question about Makita Tools & Hardware - Others
Makita bo5021 speed increases when sander lifted off work
rowdy45176
  • 2176 Answers
SOURCE: Makita 5010 will not work in random orbital mode
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Posted on Jan 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Posted on Feb 18, 2009
  • 10865 Answers
SOURCE: Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
Posted on May 02, 2009
  • 384 Answers
SOURCE: orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Posted on Jun 12, 2009
SOURCE: looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Posted on Nov 24, 2009
My sander doesn't run at full speed - it's slow. I've changed the carbon brushes but this hasn't helped.
if it sparks a lot at the brushes , then there is an armature or winding fault
sanders are cheap so junk it and upgrade
Feb 25, 2016 | Makita BO4900V Half Sheet Finishing Sander
Makita palm sdander BO5012 Manual
Go to the Makita website at
www.makitatools.com/en-us/Modules/Home/Default.aspx.
Use the search box to look up your model number. Your unit is discontinued but if you click on the red model number you'll go to a page where you can view or download the owner's manual and parts breakdown.
Oct 19, 2012 | Makita BO5012K 5" Variable Speed Random...
Hi my makita orbital sander model BO5021 no longer spins can it be fixed ? thanks in advance for any help or advice.
You should be able to fix it. If the motor hums but no rotation I would look at bearings, it really depends on what the tool is doing. BUT the good side is that I found you a breakdown so that you know what you are getting into and by going to "makitausa.com" you can download the breakdown and they also have a locator that you can use to get parts sometimes locally. Let me know if I can be of any further assistance with your repair.
Jul 04, 2011 | Makita BO5021K Random Orbit Sander 2 Amp...
Good day. How do I insert sandpaper into the Makita 9035N sander? Thank you.
looked at breakdown for the 9035 and this shows as a half sheet sander with 2 clips, they have a lever that has to be pulled away from the sander to allow you to lift up on the clamp and insert the paper under the clamp jaws when finished inserting the paper just push the levers back to their original position. You can download an owners manual by going to makitausa.com and typing in your model number. Let me know if you need more assistance.
Jun 14, 2011 | Makita Tools & Hardware - Others
I have been using a Makita random orbit sander model BO5010 for years without problems until I replaced the pad with a Porter Cable 13910, sold as compatible. Now the sander takes off, ie: increases speed...
HI, i have a feeling the pad could be the issue there. The genuine Makita one is designed for the motor, so unless the the replacement is exactly the same thickness, diameter, and weight then you will have problems. Imagine putting a small wheel designed for a car on a truck, that kind of issue. Best thing to do is to try putting the old Makita pad back onto the machine and see if that make any difference. (that is if you still have it) At work we have had similar problems where we have used non-genuine circular saw blades onto our Makita saws, and its has burnt the motor out.
Jan 13, 2011 | Makita BO5010 5" Random Orbit Sander
Orbital sander doesnt orbit!
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Speed varies on its own
You must replace the speed control module. Any Makita service certer can supply you with the proper parts.
Mar 08, 2009 | Makita 7" Electronic Sander - Polisher...
Jan 11, 2009 | Makita Tools & Hardware - Others
Tools & Hardware - Others Logo
18 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
