Question about Gigabyte GA-K8VM800M Motherboard
1. On board display card is not working 2. When we attach external vga card display is working but no BIOS image in mother board and it gives an error that BIOS image is scan. 3.Key board is not working.
  • pinku365 May 20, 2009
    On board display is not working
    External vga card attach display is working but error is
    Award bootblock Bios v1.0
    Copyright (c) 2000, Award software,Inc,
    Detecting floppy drive A media
    Scaning Bios image in hard drive
    Scanning bios image in floppy drive
    Please soved this problem
  • 20 Answers
Who makes the mother board and what bios is it using? can u access the bios at boot up? if so, is the integrated video option on? have you checked for upgrades / updates for the bios ? if you can access the bios, remove all non integrated devices from the mother board, select the option for "default settings" save and exit. then restart. after assuring the keyboard is plugged in the correct port. it should be color coded.
Posted on May 19, 2009
DEDA VGA CARD ON FUJITSU AMILO XI2528 LAPTOP
If your VGA is dead, try the VGA port to a external VGA display.
You might have to setup in your bios to External display or use you keyboards Fn key and the display button that is also in a light blue color. Most commonly it's blue. If the external doesn't work, then your video card would actually be dead. The USB vga isn't bad.
Was This Helpful? YES or no
Apr 08, 2014 | Computers & Internet
Display ic motherboard
A> Check you Power all connection proper connected.
B> Check you SMPS power proper working or not.
C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem.
D> Check you RAM, section if RAM problem then display no.
E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut.
Thanks...
Aug 26, 2013 | Dell OptiPlex Computers & Internet
ASUS K50AF no post
If the laptop boots up all the way and you don't see an image on the lcd screen or on the external monitor then the video card inside the computer is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Jun 07, 2012 | ASUS K50AF Notebook
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
I have an HP Compaq nx6310 and it turns on but doesn gives images. I try another vga ort and nothing , memory and hdd also and I've even tried repacing the CMOS battery and still nothing the thing that im...
sounds to me like your having a problem with your LCD screen,, A bad LCD or LCD inverter board can affect the mother boards bootup.
Can you see any life from the LCD?
It could also be a bad main board
May 16, 2010 | HP Compaq nx6310 Notebook
Iam change the vga chard but no display
If you added a VGA card and were using the video on the motherboard then you must disable intergrated video or select PCI(or AGP) video in the BIOS.
Jan 09, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mother Board Display Problem
Hi, i think its a vga card or onboard card, if not make sure that you ram is tight and if u can get a dust blower and blow it, and just make sure that before u close it, u quiz in tight all the attached components on the mother board, if it refuse, then get another graphics card and try a gain.For starts u can use a very cheap Pci vga card and or AGP card. The other thing that i want u to take not of is try some friends monitor and see if it works if it fails then try the first option. However usually intel has a beep code, take not of the beep code and tell us how many times the it beep.
Hope u are help.
Cheers
Apr 27, 2009 | Intel D845GVFN Motherboard
MSI board-no video or booting.
  1. Clear the CMOS by moving the jumper one step aside which located near the CMOS battery for at least 30 seconds with power cord unplugged, then put it back again to its normal position.
  2. Enter BIOS by tapping Del then load the Optimized Default, then Save by pressing F10 key.
  3. You can customize the BIOS after computer has been starting & running properly.
  4. Please check RAM and VGA card whether they have properly attached in their slots before you do the 1st step.
  5. If all above don't work, please replace your VGA card with other PCI-E VGA card that is still working fine.
  6. If all above don't work either, please replace the PSU with greater output from better brand. You can visit www.corsair.com to calculate how many Watts your system is needed for free.
  7. If hell still can not boot or no display, replace the motherboard
Apr 09, 2009 | Computers & Internet
Intel d845 gvfn display problem.
sir i have a problemmy mother board intell d845 epi/d845gvsr my mother board is cannot desplayed or display is not come but if i remove rame the mother board is give error beaps if i attach ram board is not displayed
Apr 25, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Onboard graphic (vga) chip problem
You never said that you ininstalled the drivers for the cards. Try this:
Uninstall current graphics card drivers. Right-click My Computer and select Properties. Under the Hardware tab, find the button to open the Device Manager. Your graphics card should be listed under the Display Adapter heading. Double-click the name of your graphics card to open a properties window for your current card. Last step: Under the Driver tab, click the Uninstall button.
Install new drivers. Turn on your PC and install the drivers. Windows XP should automatically recognize the new hardware and walk you through the installation wizard. If Windows doesn't detect the card, click Settings from the Start menu. Open the Control Panel and click Add Hardware. From there, a wizard will help you install the new drivers from the CD that came bundled with your new card. It's a good idea to check the graphic card vendor's Web site for more up-to-date drivers, just in case the vendor has released drivers since manufacturing your card. Once you've downloaded the drivers, simply restart your PC. Now, you're ready to start gaming.
If this doesnt work, then your card is BAD.
Let me know how you make out.
Dec 28, 2007 | Computers & Internet
Gigabyte GA-K8VM800M Motherboard Logo
405 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
