Question about Sony Playstation 3 (PS3) Console
Wireless controller stopped working even with usb cable connected
Watched a movie and the controller worked then left the ps3 running for an hour or so then put in another movie and the controller red light was on but it was unresponsive so i reset my ps3 and that brings me to this problem of it not turning on again even when i connect the usb cable no lights flash and the controller remains completely unresponsive. Controller is not very old and has not been used very much or mistreated and i'm totally confused as to why this has just happened when it was fine an hour ago?
  • criscarver27 May 19, 2009
    my contoller has the lights blinking and then they turn off and they wont come back on and i plugged the usb cable in but nothing help
  • russell_aver May 24, 2009
    reset didn't work for me only made it worse completely disconnected the control from the ps3 and turned out red lights. Once it decided to to turn back on i lost all response of the buttons. Luckily my control was still under warranty so returned it and got a new one. My only thoughts on why this happened was due to moisture in the air as we've had heaps of rain lately.
Happened to me too. There's a small reset button on the back of the controller, you'll need a biro or paperclip in order to push it.
Posted on May 19, 2009
  • spookerspook May 24, 2009
    Forgot to mention you have to pair it to PS3 again using usb cable after reset.
My controler for my ps3 is not working
Unless the controller hardware has failed, I'd surmise it has somehow lost its wireless pairing (setup of identification and link with the base unit). Connect the controller to the base unit with a USB cable and turn the base unit on. The pairing will be done automatically. Next, give the controller an ID number between 1 and 7.
Once that is done, you should be able to disconnect the USB cable and use the controller normally. (You do not have to turn off power to disconnect a USB cable.) If the Playstation base does not recognize the controller when it is plugged in with the USB cable, the controller has a bad part inside.
If the controller works normally when plugged in, but not in wireless mode, there is a problem with the wireless operation. This could be either failure in the controller or base unit, or interference from some other device nearby. For example, a furnace igniter emits RF energy over a wide range of frequencies; if the controller works only when the furnace igniter is not running (you can hear the sparks on an AM radio while it runs), then the furnace ignition circuit is the real culprit, and you should check its ground wiring.
Dec 09, 2011 | Sony Playstation 3 (PS3) Console
Why wont my ps3 controller come on
Assuming it is a fully functioning controller and is NOT malfunctioning, all you have to do is press and hold down the PlayStation button in the center of the controller. Your PS3 should turn on and the controller should have the 4 channel lights illuminate briefly, until it settles on an available bluetooth channel (usually channel #1).
Now, if the controller isn't working, then you have to charge it. To charge it, plug the mini end of the USB cable into the front of the controller and the regular end of the USB cable into the PS3. The controller will slowly charge while allowing you to actually play whatever games or movies or whatever you are trying to do with your PS3. After approximately a 1/2 hour or so, you can feel free to unplug the USB cable from the controller and there should be no further problems.
If your controller continues to fail to work after unplugging, then you may have a dead battery. You then have 3 options:
1. Live with it and just know that you have to keep the controller plugged into the PS3 via the USB cable,
2. Send the controller to Sony to have the battery replaced (or whatever other thing it is that they need to fix...assuming it's still under warranty),
3. Buy a new controller.
Dec 25, 2010 | Sony Wireless Controller for PS3
When i put my ps2 game into my ps3 its works fine but the controller will not sync it just flashes while the game is still running
keep the USB cable connected it might work since its plugged and it shouldn't loose connection! let me know what happens :)
Apr 08, 2010 | Sony Wireless Controller for PS3
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
Its a big ben wireless controller with no usb how do i connect it to my ps3
plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
Jan 18, 2010 | Sony Wireless Controller for PS3
PS3 does not detect controller even with a USB cable
hold down the ps button. and then connect a usb cable .
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
JAPANESE PS3 CONTROLLER WONT CONNECT
If You Live In Canada Or America The Controller Will Likely Not Work Because It Was Designed For A Japanese Ps3 But You Should Attach To Usb Cable To The Controller And To Your Ps3 And Leave It For An Hour And It Should Work Then If Not Then It Is Broken Or Your Usb Cable Is
Jun 27, 2009 | Sony Playstation 3 (PS3) Console
Every time i turn on my PS3 it says "system error 8013013d"
something in your ps3 is not making a good connection check your controller and see if still working without the usb cable link your controller with the usb cablee then disconnect it and see if still one light on then check your wireless control board and see if still detecting networks but I can guaranty that this is an error for something that is not working eather the blu tooh or the wireless card both are in the same board
Mar 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 controller issues
Have you charged the controllers in a while. The controler might just be running out of energy to work.
Apr 05, 2008 | Sony Playstation 3 (PS3) Console
PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
538 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
