Question about Admiral AW22 Top Load Washer
Cold water wash and rinse not working.
Hope someone can help me. My old Admiral LATA400AGE is having a problem with cold water wash and rinse. Cold water runs at start of wash for 30 seconds then shuts off. Machine will run a warm wash but stops when rinse reaches cold. Have checked screens and no blockage. Any suggestions would be most grateful. My laundry is breeding and is about to engulf the house! Laura from UK
    Problem Solver:
  • 7 Answers
Check the screens on the water inlet valve and or replace the valve
Posted on May 20, 2009
Why no cold water flow?
Could be water pressure isn't strong enough not fully open or inlet hose is clogged, bent or frozen. The screen on the hose could be clogged
Jul 23, 2015 | Admiral Washing Machines
After 2 yrs. the cold/cold selection doesn't work at all but the other selections give me hot h2o only. Also, rinse cycles just stopped working!
Your water inlet valve has 2 electric coils on it. One for hot --one for cold. The cold is probably bad. Most newer machines use COLD rinse only so if no cold fill it just stops in the rinse cycle. Replace the inlet valve which is the part on the machine back the hoses hook to.
Mar 23, 2015 | Admiral AW22 Top Load Washer
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
The cold water is not working
Most likely the solenoid on the cold water side has failed. The water inlet valve must be replaced as a unit. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/topwaterinletvideo.html
Jun 26, 2010 | Admiral 32 cu. ft. Washer
Admiral Washer Water Temperature Problems
does it have a automatic temp control? if so turn it off and see it your problem goes away.
Sep 09, 2009 | Admiral AW22 Top Load Washer
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Admiral Washing machine only runs the hot water (not cold)
if you want to use cold water, switch your hoses from hot to cold and cold to hot. You will get cold water now
Dec 06, 2008 | Kenmore Elite 45986 Front Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
151 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
