Question about Samsung Notebook PC NP-R440-JAE1US R440-11
• Digital Livecam (SCB-1100N) - Samsung Notebook PC NP-R440-JAE1US R440-11
FREE DRIVER webcam SCB-1100N
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Jan 24, 2013 | Samsung Computers & Internet
Notbook samsung np-440l driver digital livecam
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 20, 2012 | Samsung Notebook PC NP-R440-JAE1US R440-11
Phone code for spice scb 04
i want spice battery scb-05 for QT-50 mobile handset
Sep 16, 2012 | Cell Phones
Manual for Samsung SCB 2000
http://www.aseko.fi/data/attachments/SamsungSCB2000ManualENG.pdf
Jan 25, 2012 | Samsung SCB-2000 1/3 Inch Super HAD IT...
Jeep grand cherokee 2.7 crd I have a problem about code p0243 thans for your help.
DTC P0243 - Turbo/Super Charger Wastegate Solenoid A
Description: Open or shorted condition detected in the turbocharger wastegate solenoid control circuit.
Here is the flow chart for that code (some images could need to clicking for zoom)...
P0243-WASTEGATE PRESSURE CONTROL PWM
For a complete wiring diagram Refer to Section 8W.
When Monitored: When the ignition is on.
Set Condition: The ECM detects an open or short circuit in the Wastegate solenoid circuit.
Possible Causes
DAMAGED WIRING HARNESS OR CONNECTORS
WASTEGATE SOLENOID
(F504) FUSED IGNITION SWITCH OUTPUT OPEN
(K139) WASTEGATE SOLENOID DRIVER CIRCUIT OPEN
(K139) WASTEGATE SOLENOID CIRCUIT SHORTED TO GROUND
(K139) WASTEGATE SOLENOID DRIVER SHORTED TO VOLTAGE
(K139) WASTEGATE SOLENOID DRIVER CIRCUIT SHORTED TO ANOTHER CIRCUIT
ECM
INTERMITTENT CONDITION
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
Diagnostic Test
1. DAMAGED WIRING HARNESS OR CONNECTORS
Turn Ignition off.
Disconnect the ECM harness connectors.
Disconnect the Wastegate Solenoid harness connector.
NOTE: Check connectors - Clean/repair as necessary.
Are any wires or pins damaged?
Yes
Repair or replace any damaged wire or connectors.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
No
Go To 2
2. WASTEGATE SOLENOID
Reconnect the ECM harness connector.
Reconnect the disconnected Wastegate Solenoid harness connector.
Turn the Ignition on, engine not running.
Connect an incandescent test light across the supply and driver pins at the Wastegate Solenoid harness connector.
NOTE: The ECM will perform a self check of the circuit after approximately 30 seconds, which should light the incandescent test light.
Does the light illuminate brightly after 30 seconds of being connected?
Yes
Replace the Wastegate Solenoid.
No
Go To 3
3. (F504) FUSED IGNITION SWITCH OUTPUT OPEN
Connect an test light between the Wastegate Solenoid connector Fused ignition switch output circuit and battery negative.
Compare the test light brightness to that of a direct connection to the battery.
Does the light illuminate brightly?
Yes
Go To 4
No
Repair the open (F504) Fused Ignition switch output circuit.
4. (K139) WASTEGATE SOLENOID DRIVER CIRCUIT OPEN
Measure the resistance of the Wastegate Solenoid driver circuit between the Wastegate Solenoid harness connector and the ECM harness connector.
Is the resistance less than 10 Ohms?
Yes
Go To 5
No
Repair the open (K139) Wastegate Solenoid control circuit.
5. (K139) WASTEGATE SOLENOID CIRCUIT SHORTED TO GROUND
Measure the resistance of the (K139) Wastegate Solenoid driver circuit between the Wastegate Solenoid harness connector and battery negative.
Yes
Repair the (K139) Wastegate solenoid circuit shorted to ground.
No
Go To 6
6. (K139) WASTEGATE SOLENOID DRIVER SHORTED TO VOLTAGE
Measure the voltage between the (K139) Wastegate Solenoid driver circuit at the Wastegate Solenoid connector and battery negative.
Is the voltage less than 1 volt?
Yes
Go To 7
No
Repair the (K139) Wastegate solenoid driver shorted to voltage.
7. (K139) WASTEGATE SOLENOID DRIVER CIRCUIT SHORTED TO ANOTHER CIRCUIT
Measure the resistance between the (K139) Wastegate Solenoid driver circuit in the ECM harness connector and all other circuits in the ECM harness connectors.
Yes
Repair the (K139) Wastegate solenoid circuit shorted to another circuit.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
No
Go To8
8. WASTEGATE SOLENOID
Yes
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure).
No
Replace the ECM.
Keep us updates.
May 04, 2011 | 2003 Jeep Grand Cherokee
My samsumg n150 digital livecam isnt working, it doesnt show up as a device and has no programs to use it with
This is a driver issue. Go to the Samsung web site, click on Support and Drivers, put your model number in and your operating system and you should be able to download the correct driver. Double click on the driver after it is downloads and your livecam will show up as a working device.
Oct 14, 2010 | Computers & Internet
Driver Download Ethernet Driver and Network Driver for Daevoo BD 1100n Notebook.
go to acer support downloads find your machine and all the drivers will be there
Oct 06, 2010 | Acer Computers & Internet
I lose the Cd with the drivers of SCB-2424V-U how can I get it to install? thanks
the website won't allow to send direct link but from here you can access the firmware download and then you can use any program to burn cds i.e. Nero, Roxio, DVD plus, etc.
select your OS, device model: Optical Storage Slim Combo SCB-2424V-U
it will show 3 files 2 are manual 1 is firmware
if it works don't forget to rate me
thx
Apr 29, 2010 | ASUS SCB-2424V-U CD-RW/DVD-ROM (Combo)...
My samsung n130 laptop digital livecam is not working
Reinstaling drivers should help, unless is hardware malfunction.
Mar 14, 2010 | Computers & Internet
Samsung Notebook PC NP-R440-JAE1US R440-11 Logo
41 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
