Question about HP Computers & Internet
Dead screen on hp dv2000
I was using the laptop and the screen went black, however you can see the screen is working if you look at it from the side, on rebooting the laptop, the lights come on and the fan runs but the scr4een is dark and a message is visible saying that the self repair facility could not repair the fault. I have had the inverter checked and it is serviceable.There are no beep codes, so I assume that the bios is notbeing started. Any help would be most appreciated Many thanks. Jockthesock
  • HP Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 19, 2009
The backlight for my pavilion dv2000 is not lighting up. the laptop boot ugh i can see faintly, am able to move the mouse and open any program the screen remains so faint ie partially black
Well looks like your cfl tube is dead or the card powering it is dead. the easiest thing to do is to
find a Laptop repair center, the can change either the backlight tube (like a neon tube really) or the inverter or the whole screen.
You might want to try it yourself if you find a working screen for your HP.
Is is fastidious but not that dificult.
Here you can see a step by step tutorial on how to remove the screen for another Hp model.
May 17, 2011 | Computers & Internet
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi, i have an HP Pavilion dv2000 & it had recent motherboard problems, so I had it repaired in the HP Service Center. They replaced the motherboard & so far, everything was okay until yesterday....
Yes, the GPU is faulty. either replace the systemboard or reflow the GPU. Second option is cheaper and you can do it yourself. There's a link for a diy guide to fix that issue.
does your screen look like this?
http://bootmylaptop.com/hp-pavilion-dv2000-with-display-issue/
Jan 30, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
The screen on my hp pavillon dv2000 went totally black. Tried an external monitor, but nothing... still a black screen ! Help please
There are VGA port issue in the Motherboard .Pls repair it by vendor or connect any PCI gGAPHICS CARD FOR THE SAME.
Nov 18, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp 550 laptop; frozen screen then when re started blank screen
1. Can you get to any screen in the BIOS?
If so, your screen is ok. This may sound silly, but, power OFF and remove & re-seat the memory modules. Video uses some of that.
=== OR ===
2. Connect a monitor to the VGA connector on the back and use the laptop that way and so you can further debug the system
Sep 21, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000 would not start up, black screen
try to re install first the software or program then observe if the same problem,, check the lcd inverter...
Jun 07, 2009 | HP Pavillion ZV6000 Notebook
HP dv2000 gone dead
the problem occord when the battary charge full somtimes... try to switch on the laptop with battary power (if u getting the beep its k) wait for 10min and swith off the lap n turn it on.. this may work some laptops... when the battary get 100% charge the error beep will *** up... try 2 turn on the lap above 80%....
thanks
Mar 30, 2009 | HP Pavilion dv2000t Notebook
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
240 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
