Question about Chaps Luggage & Travel
Telescoping handle won't pull out- sprocket won't retract to allow handle to move up and down
3 Suggested Answers
yeroc
  • 397 Answers
SOURCE: telescopic handle
sometimes the locking mechanism for the wand wears out, make sure u have it all the way in and look where it locks and see if it looks worn
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: I have put the telescopic wand in the wrong way and cannot retract it what can I do please
Can you upload a picture of your issue? I'll try to help but I can't visualize your situation. Merry Christmas!
Posted on Dec 25, 2014
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Dec 24, 2014 | Dyson DC25 All Floors Bagless Upright...
The motor and light work but chain does not move. It is on the wheels and I cant see any problem. At first it would only raise door three or so inches now not at all. I thought manual handle might be...
Look at the drive moter sprocket to make sure that it is properly locked to the drive shaft. they sometime have a set screw locking the sprocket to the drive shaft. It also could be that the drive sprocket is locked down to the drive shaft with a set screw and a keyway. A keyway is a slot milled into the shaft to accept a square piece of square metal. Their is also a small keyway milled into the inside deminsion of the drive sprocket allowing the drive shaft to drive the sprocket.
Mar 16, 2011 | liftmaster Chamberlain Garage Door Opener...
How do i remove the timing belt tensioner without the proper tool?
TO LOOSEN THE BELT TENSIONER PULLEY ASSEMBLY, THEN POSITION A CAMSHAFT BELT ADJUSTER TOOL T74P-6254-A OR EQUIVALENT ON THE TENSION SPRING ROLL PIN AND RETRACT THE BELT TENSIONER AWAY FROM THE TIMING BELT.TIGHTEN THE ADJUSTMENT BOLT TO LOCK THE TENSIONER IN THE RETRACTED POSITION. INSTALL NEW TIMING OVER THE CRANKSHAFT SPROCKET AND THEN COUNTERCLOCKWISE OVER THE AUXILIARY AND CAMSHAFT SPROCKETS MAKING SURE THE LUGS ON THE BELT PROPERLY ENGAGE THE SPROCKET TEETH ON THE PULLEYS. BECAREFUL NOT TO ROTATE THE PULLEYS WHEN INSTALLING THE BELT.RELEASE THE TIMING BELT TENSIONER PULLEY ALLOWING THE TENSIONER TO TAKE UP THE SLACK. IF THE SPRING DOES NOT HAVE ENOUGH TENSION TO MOVE THE ROLLER AGAINST THE BELT.AND BELT HANGS LOOSE, IT MIGHT BE NECESSARY TO MANUALLY PUSH THE ROLLER AGAINST THE BELT AND TIGHTEN THE BOLT. YOU WILL NEED BELT TENSIONER TOOL OR EQUIVALENT.YOU CAN GO ON LINE INTERNET FIND THE BELT TENSIONER TOOL.SHOULD COST TOO MUCH.YOU CAN SEE IF AUTO ZONE HAS ONE TO RENT YOU.
Mar 16, 2011 | 1998 Mazda Pickup
Da Lite projector screen will not retract. It is pulled all the way down
After pulling the screen down to the desire length, The mechanism will lock itself once you stop pulling.
To retract it, you need to pull the cord down again and allow the screen to retract on its own. The screen will retract rapidly at first but will slow down to a gentle stop when it reaches the case.
Try it.
Jan 30, 2011 | Da-Lite Model B with CSR(Controlled Screen...
Removing telescopic handle of Quinny Buzz?
Pull the handle up almost all the way, the plastic pieces that hold the handle in place come out by pusining in the little black plastic dot but the handle has to be in the correct position. Move the handle up and down till you can easily push in the dot. The handle should then come off easily enough
Jul 17, 2010 | Quinny Buzz Three Wheel Stroller
How do i set the timing marks on a 3.4 liter engine
3.4L Engine Fig. 7: View of the timing chain and related components with the front cover removed — 3.4L engine 88003gb7.gif
Fig. 8: Retract the timing chain tensioner 88003gb8.gif
Fig. 9: The special tools must be used . . . 88003gb9.gif
Fig. 10: . . . to remove the timing chain, crankshaft sprocket and intermediate shaft sprocket 88003gc1.gif
Fig. 11: Slide the sprocket and chain on the shafts, maintaining the proper alignment 88003gc3.gif
Fig. 12: The crankshaft sprocket must be pressed on to specifications using a special tool 88003gc4.gif
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. For 1991 vehicles, perform the following:
    1. Remove the starter motor and flywheel cover.
    2. Remove oil pan retaining nuts and bolts. Remove lower frame and powertrain onto transmission table.
  4. Remove the front cover, as outlined earlier this section.
  5. Matchmark the intermediate sprocket, chain link, front face of cylinder and crank sprocket for reference.
  6. Retract the timing chain tensioner shoe by using J–33875 or equivalent, on both sides of the tensioner and pulling on the thru pin in the tensioner arm to retract the spring. While spring is retracted, insert a holding tool to hold it.
  7. Remove the timing chain tensioner retaining bolts.
  8. Raise and safely support the vehicle.
  9. Remove the timing chain, crankshaft sprocket and intermediate sprocket using tools J 8433 and J 28611, as shown in the accompanying figure. If the intermediate gear does not slide off easily with the timing chain assembly, rotate the crankshaft back and forth to loosen the tight fit.
  10. If necessary, remove the timing chain tensioner. To install:
  11. Check to ensure that crankshaft key is installed and fully seated and the chain tensioner is fully installed and blade retracted.
  12. Slip both sprockets and chain over the proper shaft and engage the slot in the key. The intermediate shaft may move against the rear cover. Slide the sprocket and chain on the shafts, maintaining the proper alignment shown in the accompanying figure. While installing note the following:
    1. Make sure the rubber and tension blade of the tensioner does not become caught, misaligned, or dislodged.
    2. The large chamfer and counterbore of the crankshaft sprocket are installed towards the crankshaft. The intermediate sprocket spline sockets are installed away from the case.
    3. The crankshaft sprocket must be pressed on for the final 0.31 in. (8mm) to the seated position using tool J38612 or equivalent, as shown in the accompanying figure.
    4. Check to make sure timing was maintained. Remove the retaining pin from tensioner.
  13. For 1991 vehicles, install the oil pan retaining nuts and bolts, and the flywheel cover and starter.
  14. Install the front cover, as outlined earlier in this section.
  15. Connect the negative battery cable. Start the engine and check for leaks.
Jul 09, 2010 | 1995 Chevrolet Monte Carlo
I cant fold the scooter down to fit into a suitcase
There are 3 things that can fold.
The handlebars collapse from the lever on top of the handle bar, that allows each handle to pull out.
The lever at the base of the handlebar allows it to retract.
And the lever at the base of the steering allows the body to fold against the steering shaft.
May 28, 2010 | Razor 'A' Scooter-Clear
Pull cord won't retract when housing asseembly is put back together. Works just find when not assembled. Any suggestions would be appreciated.
housing is pressing on recoil sprocket,,,,shim with washers to get clearence. Also check to see if recoil sprocket is seated all the way down aginst the stop on the crankshaft.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
How do u put timing belt for 2001 subaru outback
This is not your average timing belt replacement due to being a double overhead cam that is also an interferance fit.First remove cooling fans.2-Loosen drive belts and remove.3-Remove crank pully.4-Remove timing covers.You will see 4 cam sprockets.Theses sprockets contain single and double referance marks.You will be using the double referance marks.Rotate engine until the double referance marks are facing each other.This is to be done the same way that the American autos timing Chain systems are done but you will have 2 small double lines to line up not dots.The next step is the most important step and is of utmost imortance.THE CAMSHAFT HAVE TO BE LOCKED IN PLACE--FAILURE TO DO SO CAN RESULT IN BENT VALVES.The cam sprocket holders can be bought or rented.You can make your own as well by making 2 wedges with bolt through the middle.Slip in between sprockets and tighten enough to hold sprockets.Do not use excessive torque while tightening wedges sprockets are not made of steel but rather a composite material.Next you will have to remove the tenioner.The tensioner has to be retracted and pin istalled to hold in retracted position.The tension device has to be retracted with care or will be damaged.You can not exceed 50 pounds pressure on the plunger.The simplest method is to reract while still in vehicle, it takes 15 minutes to properly retract the plunger.By pulling up on the tensioner by hand with about 18 pounds of force --50 will be exerted at the plunger.When fully retracted insert pin to hold in reracted position.Next check to make sure that cam wedges are holding and no sprocket are trying to move,when satisfied remove one of the rollers at the bottom on the side where you left hand would be standing in front.Pull off belt.Replacement belt will have referance marksone line will go to crank sprocket face up others will line up with other sprocket marks.Reinstall roller followed by tensioner then pull pin you have holding tenioner retracted.Remove wedges.Reinstall covers fans belts.Do not be intimitaded by this replacement.Everything is very easy to get to.Be sure cams are locked and that damage is not done to tensioner and it is straight forward.
Nov 06, 2009 | 2000 Subaru Outback
Luggage & Travel Logo
59 people viewed this question
Top Chaps Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Chaps Luggage and Travel Expert? Answer questions, earn points and help others
