Question about ASUS Computers & Internet
Brand screen shows for a long time before it loads settings.
My ASUS P5GC-MX/1333 motherboard suddenly started sitting on the full-screen motherboard picture for long time periods (about 1-2 minutes) and then doesn't load up my operating systems. It seems as though my hard drives are listed out of order as well - even when I manually change them to the correct position in the bios.
    President:
  • 814 Answers
Try taking out the harddrive and putting it in another computer. Boot up the computer and see if window does a scan disc for errors before booting the system if it does then you know that something corrupted your system. the next step is to allow the other computer fix the hard drive with repair disc tools in the properties of the harddrive.Do a scan disc and automatic fix errors scan. Also do a scan disc and restore bad sectors fix. Do a complete of the defrag of the disc.If this is not the problem.You will need to check the bios ans see if it has become corrupted. check all the functions and see if anything has changed from your original settings. If it has do a restore by loading default settings.Try to boot up your computer and remove any new programs you may have downloaded just before you started having the problems. If you cannot boot go into the bios again and change the boot sequence to disc and load the windows disc to boot in safe mode to try to remove the programs.See if the system restores to normal operations. If not use the discs repair function to fix problems with windows that may have happened from the corruption.This problem could also be a hardware problem like a bad power supply or motherboard. These should be tested for problems before doing all the windows and hardrrive testing. Just to make sure you are not going in the wrong direction with the repair. Check the power supply with a power supply tester to see if it is working correctly, check to see if its is full of dust and dirt tha maybe affecting its operation. do a check of the condition of the motherboard for bad components like capacitors that maybe causing a problem with voltage regulation to the boards processors.Check the main processor and its heatsink and make sure that it is seated properly and the fan is working correctly.If all this look good and working, then work on the harddrive and windows problems.Be sure to test the operation of the system after each fix or repair to see if you have foun the problem.I hope this helps you with your problem.
Posted on May 20, 2009
Need to turn on achi mode for my asus p5gc-mx/1333
When you start your system press "F2" or "Delete" button ( before the windows splash screen and before the system starts checking the hardware.) this will take you into the BIOS you will find the setting you require in there.
Dec 06, 2012 | ASUS P5GC-MX/1333 Motherboard
ASUS P5GC-MX/1333 Motherboard can be match this model..processor...E5400.....
YES!
*E5400 Socket 775 45nm Dual-core Processor with 2.7GHz
*ASUS P5GC-MX/1333 is Socket 775
Jun 12, 2010 | ASUS P5GC-MX/1333 Motherboard
Audio sound free download
Download the drivers from Asus. Enter you're bios and make sure the Audio is enabled or set to [Auto]
http://usa.asus.com/Search.aspx?SearchKey=P5GC-MX/1333
Mike
Apr 23, 2010 | ASUS P5GC-MX/1333 - Motherboard - micro...
Power supply FOR ASUS P5GC-MX/1333
Dear,
Yes you can use that power supply for both one.
Cheers
Jaggu
Oct 18, 2009 | ASUS P5GC-MX/1333 Motherboard
P5GC-MX/1333 cannot support recovery card?
I have installed win XP I have problem loading realtek HD audio driver
my MOTHERBOARD is P5GC-MX/1333
May 13, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Computers & Internet Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
