Question about Gamo Pt-85 Blowback
Magazine jammed will not release
How do you clear a nail jam
there is a clasp someplace on the magazine or " release" it then should slide back about a 2" and that s how that s done. better to find why its jammed unless you already know.
Sep 07, 2015 | Senco Air Tools & Compressors
How do you open the base unit to remove the cd changer magazine
The top cover is held on with 4 clips (similar to those on a car door card) so needs to be gently prised off, this will expose screws etc to enable the bottom cover to be removed.
Ive done this with my system but it does not really help solve the problem, I still can't get to the jammed disc!!
Jul 07, 2014 | Bose Lifestyle 30 System
Jammed nail in it how do i get it out with out paying to fix it
unplug the air from tool, depending on where the nail is jammed you might want to remove the magazine to get to the back of the nose assembly, some have a quick release for this reason. then depending on the jam you might have to take a punch and knock the driver back up to remove the nail. Hopefully it is not jammed that hard
Feb 11, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
The 4 disc magazine is jammed and wont eject
was the unit recently shipped to you ? if so open top cover , if the empty magazine was left inside the cd trays can slide out into the playing area and jam the unit ,check it like that anyhow . sometimes u can see a small metal tab to release the magazine maNUALLY
Jan 13, 2010 | Car Audio & Video
Hasselblad 500cm body frozen/jammed
Check the release button lock tab, it may be engaged, holding the release button in
Aug 17, 2009 | Hasselblad 503CX Medium Format Camera
Error 1 on alpine cha-s364
Quick Note: It's really helpful to your cause if you make sure you include more information about your system and what you're doing to get an error.
It's also a good idea to make sure you type in your model number correctly - you've typed in cha-s364 (the actual model you're talking about "I think" is a CHA-S634 - please verify!!
Here's a link to the user manual
As for the E-01 Error message on your CD Changer:
The E-01 reading is an error message, usually because the changer magazine is jammed in the changer. To manual eject out the magazine, take a thin plastic ruler (at least 5-1/2" in length) and slip it between the bottom of the magazine and the changer. Now, push in. This will hit a release button in the back. If the magazine does not eject, you will need to send the unit in to be serviced. To locate the nearest authorized service center to you call 1-800-ALPINE-1.
Note: if the magazine is half way out, but jammed, DO NOT try to release the magazine. You will need to send the unit in to be serviced by a technician.
May 29, 2008 | Alpine Car Audio & Video
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Gamo Pt-85 Blowback Logo
156 people viewed this question
Top Gamo Sport & Outdoor - Others Experts
Bill Eager
Are you a Gamo Sport and Outdoor - Other Expert? Answer questions, earn points and help others
