Question about Fitbit Flex Wireless Activity & Sleep Wristband
Fitbit flex blinks 2 lights
Tapping 2 blinking lights
Need to order fitbit flex 2 charger
Amazon, QVC, eBay and others offer the fitbit flex charge 2. However, you have expressed this as if you simply need a charger for the device. A UL tested wall charger would do that according to the Fitbit community.
Just how much support you would get from a particular vendor is a good question to think about.
Oct 21, 2017 | Exercise & Fitness
My Fitbit flex quit syncing with my app on my phone
I would try these steps to try to get it to sync again.
1. Make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit in your Bluetooth settings.
2. Try removing the Flex in the Fitbit app (should be under device settings) and then reconnecting it.
3. Try resetting your Flex.
Oct 19, 2017 | Exercise & Fitness
How do I latch my fitbit
Can't get my flex strap fastened. - Fitbit Community
https://community.fitbit.com/t5/Flex/Can-t-get-my-flex-strap-fastened/td.../194515
  1. Cached
  2. Similar
Mar 3, 2014 - I have trouble fastening my Flex, too. Not only is it difficult to line up the holes with the latch, but I somehow can't press hard enough to click the ...
Clasping and switching your Alta wristband - Fitbit Community
https://community.fitbit.com/t5/Alta/Clasping-and-switching-your-Alta.../1239815
  1. Cached
03-14-2016 13:19 - last edited on 04-25-2016 16:54 by ErickFitbit Moderator. Options. Mark as ... How do I clasp my Alta wristband more easily? Before putting ...
Solved: can't fasten band to wrist - Fitbit Community
https://community.fitbit.com/t5/Flex/can-t-fasten-band-to-wrist/td-p/536044
  1. Cached
  2. Similar
Since it wasn't on my wrist, I could see how to align the band to get the clasp to go through both pieces of ... HelenaFitbit ...... I cannot get my fit and to latch at all.
How can I latch the band easily? - Fitbit Community
https://community.fitbit.com/t5/Flex/How-can-I-latch-the-band-easily/td.../98355
  1. Cached
Jan 19, 2014 - Latch is very difficult. Accepted Solution. 0 Votes. Reply · All forum topics · Previous Topic · Next Topic. 1 REPLY. 01-19-2014 20:16. Options.
Anne Corey - I can't attach my Flex to my wrist. Can not... ' Facebook
https://www.facebook.com/fitbit/posts/595334813824040
  1. Cached
  2. Similar
I can't attach my Flex to my wrist. Can not get the little teeth to go ... To see more from Fitbit on Facebook, log in or create an account. Sign UpLog In. Not Now. How do latch my fitbit Google Search
Dec 28, 2016 | Exercise & Fitness
How do i charge up my fitbit?
      To charge your tracker:
      1. Remove your tracker from the wristband:
      2. Insert your tracker into the charging cable. ...
      3. Insert the charging cable into a USB port or UL-certified USB wall charger.
      4. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
      More items...
      Help article: How do I charge my tracker? - Fitbit Help
      https://help.fitbit.com/articles/en_US/.../How-do-I-charge-my-tracker Fitbit
    Feedback
    https://help.fitbit.com/articles/en.../How-do-I-charge-my-tracker
    FitbitDec 12, 2015 - To charge your tracker: Remove your tracker from the wristband: Insert your tracker into the charging cable. Insert the charging cable into a USB port or UL-certified USB wall charger. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
    Fitbit Help - Getting Started
Jan 21, 2016 | Exercise & Fitness
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
Why does my fitbit have Two lights flashing
Your Flex features
a
display that consists of 5
The lights behave
differently depending on what the tracker is doing.
Goal
t
racking
The indicator lights illuminate as you hit 20% increments towards your goal.
Tap your
Flex to see your progress.
When you reach your goal, Flex will celebrate by buzzing
and flashing its lights
Feb 01, 2015 | Miscellaneous
Why and how does my fitbit flex go into "sleep mode?"
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
Jan 11, 2015 | Fitbit Flex Wireless Activity & Sleep...
Why is the fitbit have 2 dancing lines when i hit it twice
It is in sleep mode. To get it out of sleep mode you have to tap rapidly for 1 to 2 sec
Sep 10, 2014 | Fitbit Flex Wireless Activity & Sleep...
Fitbit Flex Wireless Activity & Sleep Wristband Logo
1,057 people viewed this question
Top Fitbit Exercise & Fitness Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
