Troubleshooting asko w6362 washing machine
Set on quick cycle start light flashing have emptied trap
3 Suggested Answers
  • 713 Answers
SOURCE: washing machine fills and washes
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 08, 2010
SOURCE: cannot stop cycle once it has been started and temp is too high
See manual for reset - HOLD stop-button for more then 5 seconds, thats solves the problem :-)
Posted on Feb 20, 2011
Asko 6762 does not complete filling with water. It also wont complete spin cycles. The drain pump sometimes runs continually after the tub is empty. Have cleared the coin trap and the hose between the tub...
Sound like it could be some "dirt" in the "air-trap-tube", so the machine dont get the signals that says it's empty. This also can also make problems for filling. This "air-trap" is the plastic tube, mounted upwards on the bellow hose, between drum and pump.
Could also be a pressure switch, or pressure sensor problem, but this is not very common:)
Oct 04, 2013 | Asko W6221 Front Load Washer
Tip
Asko W6021 would not fill with water
Our W6021 front has had a couple of instances where it would not start the fill cycle as usual. Normally it would be switched on,the relay would operate and the water would begin to enter the bowl. We tried a number of things including checking the hose and inlet filter for blockage. We then checked the outlet drain pump trap and found a coin and a drill bit lodged in the entry hole to the trap. Once the foreign objects were removed ,the machine operated as normal once again. I will be very careful in future to empty my pockets of metal things.
on Jun 15, 2007 | Asko W6021 Front Load Washer
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
Asko washer W6021 Soap door will not open
listen to it, if it does a quick rinse, then empties the water at the beginning of the cycle, then the next cycle will be the wash cycle.
May 17, 2011 | Washing Machines
My asko regardless of selected wash program stops after the main wash, it will drain the water, but then not start the rinse cycles. The washing machine will allow you to open the door. I thought it was...
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Also please note
with the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rotate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes.
Nov 29, 2010 | Asko W6021 Front Load Washer
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Cannot stop cycle once it has been started and temp is too high
May 22, 2009 | Asko Washing Machines
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
Ariston Washing machine A1636 - Flashing lights
what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
Jun 20, 2007 | Ariston Technologies AW149NA Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
