Question about Philips Audio Players & Recorders
Alarm clock does not keep time
Philips Docking system for iphone and ipod model dc290/37 Once we set the clock it doesn't keep time just stays at whatever time we set.
techman
  • 3130 Answers
SOURCE: RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Posted on Mar 24, 2006
IB4G2008
  • 3587 Answers
SOURCE: Setting Time
ok..here it is, right from Fixya's manual pages..
click here
Posted on Feb 24, 2008
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Posted on Nov 30, 2008
SOURCE: I can not figure out
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Posted on Jan 05, 2009
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
Operating manual for Plain Lazy Alarm Clock iPhone/iPod Speaker Dock
No instruction manuals for the 'Plain Lazy' ipod docking station/alarm clock found on line :-( So after tinkering with the buttons for quite a while, II have worked out how to set the clock. Press & hold the play/pause button & at the same time press the skip back button once....let go of both buttons. Then immediately press the play/pause button again once & the clock numbers will start flashing. Press the skip back button to adjust the hours & skip forward button to adjust the minutes. Press the play/pause button to set!
Aug 04, 2012 | Audio Players & Recorders
What features does the iPod/iPhone alarm clock have?
The Memorex iPod/iPhonealarm clock has the following features:
  • Dockingfeature for iPod/iPhone
  • iPod, radioor buzzer alarm settings
  • Sleep timer
  • FM radiowith preset stations
  • Batterybackup
  • Dimmerfunction
  • Line Jackfor connecting to other audio devices
Jul 23, 2012 | Memorex 02169 Ipod iphone Mini Alarm Clock
How do you set the time on RC591-A (RCA Docking Alarm Clock)
None of these answers works! When I tried the first option, the clock DID NOT flash at 12:00 a.m. Since that didn't happen, none of the following steps did either.
The second option didn't work either. Holding the set key never made the display go to a colon, flashing or otherwise. Again, using the forward and back keys didn't work as described.
The third option with a link to another website led to instructions on a power tool and had nothing whatsoever to do with the clock on the docking station.
The fourth option doesn't give any instructions after you hit the time you want to set. The time DOESN'T stay where you set it. It once you release the forward or backward keys, it reverts to the original time that was on the clock to begin with.
None of these answers works at all. I was given the iPod touch and the radio docking station secondhand from my sister and she doesn't have either the instruction manual or the special batteries that go in the battery compartment. The clock on the iPod itself is fine. I finally figured out (on my own) how to turn off the danged alarms and timing mechanisms but cannot set the clock.
Nov 07, 2011 | Audio Players & Recorders
How do you set the clock and alarm on the Starlite Next Play Clock Radio with iPod Dock NP105CR
Setting the clock for the Ipod docking station
NP105CR
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
Jun 23, 2010 | Starlite Next Play Clock Radio with iPod...
I don't know how to make the Ipod go dark after it is on the clok
first set then alarm. then set your ipod lock time to 1 min. you can fine it on your ipod setting. hope i help you.
Jan 11, 2010 | Digital Products International Clok Smooth...
Alarm clock and time w/ clok smooth ipod system
Setting the clock
Setting the Alarms
Nov 28, 2008 | Digital Products International Clok Smooth...
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
