Question about Lionel The Polar Express Train Set
Train does not chuff
JUST PURCHASED TRAIN IN DECEMBER OF 2013. TRAIN INTERMITTANTLY CHUGS OR NOT AT ALL WHEN MOVING FORWARD
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
Receipt for December 2013
This is a help forum not the vendor or store you purchased your product from. Contact whomever you bought the tabelt from.
Nov 03, 2014 | Visual Land ME-110-16GB-BLK - Prestige 10...
To check my gmail
Doesn't sound like the ex is the stuppid one here.
May 17, 2017 | Cameras
I have a 1950's engine and transformer. I run it every year a Christmas. Last year the reverse direction switch started working intermittently. I would press it multiple times and occasionally it would...
Turn the power to the track off and then back on. The engine may stay still because the train is in neutral. Turn the power off and on once again. The engine should now go forward or reverse. Turning the powere on and off again will return the train to neutral. On and off again should make the train move in the opposite direction. If all of these steps work then the problem is in the "Direction" button of the transformer. But if the problem still persist, than the "E" unit in the engine needs to be serviced. More times than not it is the E unit. The direction button is a simple momentary off switch that has few moving parts.
Nov 09, 2010 | Lionel New Haven Freight Train Set
I have a nocking noise from front of my freelander
hi, im not a mechanic but i had similar problem with my freelander and it was the ird unit (or transfer case ). the shims thorned and there was some damage to the gear
Sep 25, 2009 | 2002 Land Rover Freelander
Thomas the Train Ride on Train only goes backwards
Check the battery. It sounds like you have it in, backwards.
Sep 17, 2009 | Toys
PRIDE GOGO 3 WHEEL MOBILITY SCOOTER NOT USED FOR 3 WEEKS BUT KEPT CHARGED-NOW WONT GO -IT CHUG CHUGS AND THEN STOPS AS THOUGH THE BRAKE IS JAMMED ON. THE OTHER DAY IT DECIDED TO GO 200 YARDS USING FWD AND...
sounds to me like the power controller pot located on the handlebar lever that you use to go forward and reverse ? , is there any up and down movement with this lever , if so that will be causing intermittant power delivery.
Apr 25, 2009 | Pride Sonic 3 Wheel Portable Scooter
Peg Perego Thomas Train Track Rider
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Lionel The Polar Express Train Set Logo
51 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
